01-12-2012, 07:18 PM | #1 |
RCC Addict Join Date: Nov 2009 Location: cleveland,Tn
| ax10/hbz warthog
ok guys i need help i have a hbz warthog chassis have been running it for a while just goofing off but the way its made the lower links hit the upper links where the uppers mount to the chassis im losing alot of flex in the rear no matter which way i try diff ways it dont gain anything. so im gonna go back to a normal ax10 chassis so that i can run a bug body. do i need to go with the stock ax10,benders or etc...... please keep all the needed helping suggestions coming. im running the novak goat 18t and esc with a 3 cell lipo and rear steer.
01-13-2012, 12:11 PM | #2 | |
Rock Crawler Join Date: Oct 2011 Location: Co,Cork..Ireland
| Re: ax10/hbz warthog Quote:
Post some photos for more help... .; | |
01-14-2012, 07:14 PM | #3 |
| Re: ax10/hbz warthog Last edited by ax10tn; 01-14-2012 at 07:16 PM. |
01-14-2012, 07:16 PM | #4 |
Quarry Creeper Join Date: Oct 2007 Location: Sheboygan
Looks like the chassis is designed to run straight lower links.
01-15-2012, 06:26 AM | #5 |
Quarry Creeper Join Date: Nov 2011 Location: Cookeville
I would love one of those chassis for my lil boys build where might someone run across one of those cant seem to find them for sale anywhere ? That rig looks very nice man. I tend to agree tho it looks like it needs straight links in the rear.
01-15-2012, 07:06 AM | #6 |
Hbzusa.com I think is the website
01-20-2012, 09:18 PM | #7 |
Pebble Pounder Join Date: Dec 2009 Location: Magalia, CA
Im also running the warthog chassis. I found that running straight lower links in the rear will give u more flex. Also run your rear shocks at the first mounting holes to lay em down more flat. It will lower your cog a lil and help with body roll.
01-20-2012, 09:33 PM | #8 | |
thanks rockstar ill try that. | |
01-21-2012, 12:12 PM | #9 |
Cool cool! Post up some flex shots after you getter done!!
01-21-2012, 12:12 PM | #10 |
What beadlocks are you running?
01-22-2012, 02:08 PM | #11 |
i am running the proline 8 shooters with custom rings. search them on ebay under proline 8 shooters should pull them up he his in buford,ga im running them on the warthog and on my wraith and love them. ive never had one to pull a bead off other than my 2 yr old son grapping and pulling it off lol.. i think they were like 30 bucks for all four wheels all 8 rings and longer bolts
01-22-2012, 02:11 PM | #12 |
| Re: ax10/hbz warthog |
01-22-2012, 04:13 PM | #13 |
sweet. i like em!
02-04-2012, 08:59 PM | #14 |
Newbie Join Date: Jan 2010 Location: Nor-Cal
I run bent lowers on mine but I have mounted them on the outside of the chassis and they clear fine. I'm running the same shock and spring rates as you also and it does make a huge difference to mount the rears in the forward most hole.
02-04-2012, 10:21 PM | #15 |
| Re: ax10/hbz warthog thanks i had another guy tell me that but i tried it and the way mine is i had no flex withthe shocks in the foward most hole because my links are to the inside of the chassis but i went back to a stock chassis so i could do a bug body but thanks for the info... im selling the warthog chassis if ya need another one.
02-04-2012, 10:23 PM | #16 |
update..... i switched back to the stock chassis only because ive wanted a bug crawler for a long time. |
ax10/hbz warthog - Similar Threads | ||||
Hbz warthog | Skier | Newbie General | 1 | 04-06-2011 06:52 PM |
hbz warthog | ax10tn | General Crawlers | 2 | 01-14-2010 10:48 PM |
Best shocks for hbz Warthog chassis? | Al3eRtO | Axial AX-10 Scorpion | 4 | 11-16-2009 06:32 PM |
Berg Axles on HBZ Warthog | jeepster73 | Newbie General | 9 | 12-28-2008 02:53 PM |
HBZ Warthog + ARTR AX10 1 Night build. | Brandon | Axial AX-10 Scorpion | 77 | 09-27-2008 11:42 AM |
