Thread: Ax10 comp rig....Kinda
Old 09-01-2013, 08:51 PM   #1
Default Ax10 comp rig....Kinda
Hey everyone, ive been out of crawling for a while because i was building short course trucks and 1/8 scale buggies for racing, now that winter is coming i figure i should get back to my roots...crawling! I got this crawler in a trade a while back, i built it up from basically stock form, nothing custom here is the parts run down
Axial ax10 axles
Axial ax10 tranny
Axial Bender SWX chassis
Axial bender custom front & rear 4 link plate
Axial Under Over ring & pinion
Junfac metal drivelines
Losi Comp shocks
Losi MRC lower links
Vp Hurtz dig
Vp C-hubs
Vp Knuckles
Vp VVD's
Vp Dirty Hairy wheels
HB rovers (white compound)
Savox SA-1283 SG
Soon to have
-Tekin FXR
-Tekin 55T brushed motor
-Spectrum receiver
-Beef tubez
-C.I. foams
ill update this thread as i make progress on it
XJkid93 is offline   Reply With Quote
Old 09-01-2013, 09:17 PM   #2
Default Re: Ax10 comp rig....Kinda
Looking real good so far. What body is that?
Hittman is offline   Reply With Quote
Old 09-01-2013, 09:29 PM   #3
Thanks, its the proline bug body.
Old 09-01-2013, 10:32 PM   #4
It is? It looks a lot different than the proline bug. Definitely doesn't look as big as the proline body.
Old 09-01-2013, 10:38 PM   #5
i think its an older version of it, all i know is that the bug body was around my town since the original AX10 was released, the owner of our local hobby shop got that body for his scorpion. it has the split down the center of the hood, if you look at my other thread i have a true proline body and your right the other bug i have is bigger, this body is very low and doesnt have the part where it sticks out for the windows.
Old 09-01-2013, 11:00 PM   #6
Got it. Thanks for the reply. I will have to do some searching, because I really like the looks of this body.
Old 09-01-2013, 11:05 PM   #7
No problem, if I find one ill send you a PM as well
Ax10 comp rig....Kinda - Similar Threads
R2J's AX10 COMP RIG R2j Axial AX-10 Scorpion 12 08-21-2009 09:10 PM
ax10 comp rig- which offset? jedsled Tires and Wheels 2 10-21-2008 02:25 PM
