Thread: Chevotafun 5th D Sucker Punch
Old 01-16-2014, 09:19 AM   #1
Default Chevotafun 5th D Sucker Punch
Hey guys here is my 5th D sucker Punch.
Got so excited to build this truck that I for got to take a lot of pictures along the way, lol
Parts-
5th D Sucker Punch
Chaotic links
Chaotic front/rear Plates
RcBro's knuckle weights
Creation Fab Beef Tube
Vp wraith knuckles
Over/Under drive gear
Hulktsa trans
NCD 3D CF rims
Silver Voodoo
CI 6" Comp cut foams
SCX Icon shocks
Elecitronic's-
Hi-tech 7954
Holmes hobbies BR mini
HH 30t Flow 500 puller
3S Gens Ace 450mah batteries
These pictures are of it when I first built it
chevotafun is offline   Reply With Quote
Old 01-16-2014, 09:22 AM   #2
Default Re: Chevotafun 5th D Sucker Punch
Here are some pictures of it after the Hulk's trans went in and the Icon shocks plus the NCQ CF rims
Weight after the changes - 3lBS 10oz
Need to finish the front drive shaft and put some new wires to the motors.
PLus still have some more alum hardware to add as well.
In the bottom pic I remove the spacer's for the outer cross brace as well.
Old 01-16-2014, 12:28 PM   #3
5th D Owner/Driver
cboggs's Avatar
Looking good! I don't see any knuckle weight?
cboggs is offline   Reply With Quote
Old 01-16-2014, 12:55 PM   #4
Thanks Chris
The knuckle weight is there look through the front rim you can see the brass
1.25oz per side
How much knuckle weight are you running?
It seems to have a good forward bia's but we'll see once I get it wired back up.
It might even be too much
The front feel pretty heavy.
Old 01-16-2014, 01:24 PM   #5
TSK
Shelf queen
TSK's Avatar
Looks good mang. I was wondering when this truck was gonna show up online.
Did the Hksta grand just drop right? Are you using any of the existing transmission holes to fit it or did you need to drill fresh holes or utilize an adapter plate?
**Edit** I see the adapter plate now.
3.1lbs
TSK is offline   Reply With Quote
Old 01-16-2014, 01:44 PM   #6
3.1lbs
Yeah I was going to do a build tread earlier, but got so excited to build it I forgot to take pic's along the way
As for the trans
One hole on the driver side lined up then I used a CF plate to screw the other side down.
notched alittle hole in the skid for the head of the screw to sit in.
Then i screwed the plate down to the stock holes.
I did think about drilling new holes, But with the cf plate it gave me the couple mil I needed to move the trans forward, without interfering with the rod ends.
Yes sir 3lbs 10oz
I think when I finish with the alum hardware and acouple other tweaks it will be around 3.8lbs.
Old 01-16-2014, 03:04 PM   #7
Enjoy the rig it looks really good... I couldn't be any happier with my SP rig.. good choice on the chassis.
Now you need some titanium negative space wheels.
tapped-out is offline   Reply With Quote
Old 01-16-2014, 03:35 PM   #8
Thanks Man
I agree I couldn't be happier with the SP
It just works
Not to many place's my xr will go that the SP won't
HMM glue on rims there somemore weight lose
Old 01-16-2014, 07:49 PM   #9
Looks like you could turn ur wheels into glue ons pretty easy. Some new standoffs or put spacers in, that are the width of ur beadlock.
Rig looks sweet with that tranny in! Not that the SP doesn't look sweet without it.. ;)
I guess its time to dig the one I have out an start building it.. :confused::what:
winnerone23 is offline   Reply With Quote
Old 01-16-2014, 11:40 PM   #10
I look forward to seeing this beat run, your a damn good driver with the xr.
maxxis77 is offline   Reply With Quote
Old 01-17-2014, 08:11 AM   #11
Good Call
Yes get building, you will love this chassis
it just works
Thanks Bud
Hope you get your sporty together for this yr
Old 01-24-2014, 10:08 AM   #12
Alittle up date.
Got the tranny issue's all figured out,
Thanks Dan (Hulksta)
This guy is awesome to deal with and take's care of his customer.
If you need to know what the problem was goto Hulksta vendor page as he covers all of it.
He has fixed the problem and should be a issue from here on out
Went from a 18t to a 20t pinion and made a big difference.
Might even try a 22t pinion as I think I could still use alittle more pop.
Hopefully my alum screw show up soon so I can finish replacing screws.
Also got some narrowed voodoo's coming as well
Old 01-25-2014, 07:22 PM   #13
Just noticed your thread, I don't get much time to browse the forum these days
Looking at the pic in post #2 looking down.. it is so small, chassis builders need to take advantage of it and shrink the chassis down now
Hulksta is offline   Reply With Quote
Old 03-26-2014, 11:37 AM   #14
Well guys
We had our first outdoor comp on sunday and my sucker punches first comp and well she did freaking awesome couldn't be happier on how the sucker punch preformed.
The old SP pulled out a first place.
Old 03-26-2014, 12:05 PM   #15
Originally Posted by chevotafun View Post
Well guys
Nice, good to hear.... do you guys post scores? I need some videos...
Old 03-26-2014, 12:15 PM   #16
TSK
Shelf queen
TSK's Avatar
I never get tired of hearing that
Congrats oon the great finish
Old 03-26-2014, 01:52 PM   #17
Ummm, Mr Chevotafun...you omitted to say it was a one-two punch for the SuckerPunch's on Sunday.
Well, a 1st and a tie for 2nd.
Solitaire is offline   Reply With Quote
Old 03-28-2014, 11:04 AM   #18
Sorry Sir you are correct
it was a one two combo
With the SP taken first and second.
Nice driving Bob.
Old 03-28-2014, 11:18 AM   #19
Here is a link to our score's
https://docs.google.com/spreadsheet/...eets_web#gid=0
Should have some video up hopefully soon.
Old 03-28-2014, 12:17 PM   #20
TSK
Shelf queen
TSK's Avatar
Looks like you were killing it all day
What is the outlaw class?
Chevotafun 5th D Sucker Punch - Similar Threads
cboggs' 5th D Sucker Punch cboggs Axial AX-10 Scorpion 299 10-06-2018 02:24 AM
Tapped-out's 5th Dimension Sucker Punch tapped-out Axial AX-10 Scorpion 109 08-11-2015 03:17 PM
Tapped-out's 5th Dimension Sucker Punch tapped-out Videos! 0 08-11-2013 01:37 PM
