Thread: 2.2s Track Width?
Old 08-26-2017, 01:09 AM   #1
Default 2.2s Track Width?
It's been a while since I built a 2.2s and just curious what track width most guys are shooting for these days.
I'm making a set of DE wheels slw compatible but I'm going to need to purchase hubs since the largest I have currently are 475's.
Also I'm not sure where the rules are posted these days? Most of the threads I find are outdated.
bmuzz1 is offline   Reply With Quote
Old 08-26-2017, 05:29 AM   #2
Default Re: 2.2s Track Width?
Check out Fish's Crawler Parts for their hub spacers. Can get the exact width you want out of any slw hubs without buying new hubs.
I believe currently I am running an 11" width up front and 10" rear. I will have to double check but pretty sure that it.
HilltopRcCrawlers
Chapter 5
Good Fellas
TEAM FCP
doug.steele04 is offline   Reply With Quote
Old 08-26-2017, 05:33 AM   #3
Should be able to find rule info here.
https://m.facebook.com/story.php?sto...98446036855880
HilltopRcCrawlers
Chapter 5
Good Fellas
TEAM FCP
Old 08-26-2017, 05:49 AM   #4
HilltopRcCrawlers
Chapter 5
Good Fellas
TEAM FCP
Thank you for the response.
Okay so I wasn't too far off on the track width and if I remember correctly 11" is the max allowed.
Old 08-26-2017, 05:53 AM   #5
I believe max track width is 12.5
HilltopRcCrawlers
Chapter 5
Good Fellas
TEAM FCP
Old 08-26-2017, 09:23 AM   #6
HilltopRcCrawlers
Chapter 5
Good Fellas
TEAM FCP
Just looked at the rules and you're correct, 12.5" width.
Old 08-26-2017, 10:53 AM   #7
Custom Carbon Fiber
Robbob's Avatar
I run around 11'' front and 10.5(ish) rear on my rigs.
My sporty's a little narrower in the rear, Id say more around the 10.25ish with Wraith stock plastic hubs. Feels like a good sweet spot for my driving there.
Robbob is offline   Reply With Quote
Old 08-26-2017, 11:46 AM   #8
5th D Owner/Driver
cboggs's Avatar
10.75" front and 10.25" rear for me on AR60's.
cboggs is offline   Reply With Quote
Old 08-26-2017, 11:47 AM   #9
11.5 front counting the 3/16" or so of toe out on both rigs and 11 and 10.75" on rear. El pinko is 11" out back with regular shift hubs but I have narrow shifts to swap on it so it will be the same as frank.
WHITE-TRASH is offline   Reply With Quote
Old 08-30-2017, 07:05 AM   #10
Thanks for all the feedback guys.
I just received my Shift hubs from TCS yesterday, just waiting on a few more parts before I start my build.
My axles are XR width SCX axles front and rear.
I also got a set of 1" CI 6bolts in case the DE's don't work out to my liking.
For chassis I'll be using the Krazed Builds Unstuck
Old 08-30-2017, 11:00 AM   #11
With xr width you should be an easy inch narrower than my rigs with DE wheels.
2.2s Track Width? - Similar Threads
How to pick wheel width and track width, Help please toy4crawlin EnRoute Berg 6 06-16-2011 09:59 AM
Track width, vanquish rims what width and hbs? Kraqa RC4WD Bully 10 01-14-2010 08:50 PM
