Upper link plates http://images.tapatalk-cdn.com/15/06...2a9d88886a.jpg I designed and cut these plates out of Delrin, 1 rear plate and 1 front plate with servo/battery mount. Sent from my SM-G900V using Tapatalk |
Re: Upper link plates The link plates worked out perfectly. I will be using them on my sporty class rig. I used 1/8" Delrin, cut with a laser. http://images.tapatalk-cdn.com/15/06...71fbcca14f.jpg http://images.tapatalk-cdn.com/15/06...2e877be365.jpg http://images.tapatalk-cdn.com/15/06...a4972d2d90.jpg http://images.tapatalk-cdn.com/15/06...8a58c2a490.jpg Sent from my SM-G900V using Tapatalk |
Re: Upper link plates Thats a smooth front drive shaft..... |
Re: Upper link plates you dont notice any flex with that third screw not being in there? |
Re: Upper link plates No, it's pretty solid, it's 1/8" delrin. Sent from my SM-G900V using Tapatalk |
Re: Upper link plates It's not the delrin "I" would worry about flexing.. My rear plate will twist the 2 posts and the brace, with the 3rd screw in it.. I replaced the axle brace with an aluminum one and had to run longer screws in the 2 axle housing posts.. I still get flex in harder binds.. just watch it.. It will rip the 2 screws out, over time, from the flexing.. Sent from my XT1080 using Tapatalk |
Re: Upper link plates Like said above, your going to need that 3rd screw in there. |
Re: Upper link plates I'm actually going to throw in the 3rd hole on monday. Sent from my SM-G900V using Tapatalk |
Re: Upper link plates I did a mockup today on my chassis today with some links I had laying around, getting Ti ones soon, but I am adding the 3rd hole, really didn't think it needed the 3rd hole till I did the mockup. http://images.tapatalk-cdn.com/15/06...c05ef70e72.jpg http://images.tapatalk-cdn.com/15/06...2af3b85e34.jpg Sent from my SM-G900V using Tapatalk |
Re: Upper link plates For a guy thats been crawling for a year with all self made chassis and bits - Your looking great Scott. *Man they grow up so fast** |
Re: Upper link plates I ended up adding the 3rd hole in the the rear plate for more rigidness. http://images.tapatalk-cdn.com/15/06...096aa6cd80.jpg Sent from my SM-G900V using Tapatalk |
Re: Upper link plates So I redesigned the servo/link plate, works out much better. I was able to mount the esc on the underside with the battery on top, the servo is now vertical sitting on top of the axle giving it more LCG. http://images.tapatalk-cdn.com/15/10...e16af82012.jpg http://images.tapatalk-cdn.com/15/10...626f516a52.jpg Sent from my SM-G900V using Tapatalk |
Re: Upper link plates Ooohhhhhh, your going to love it! When I designed that plate and started running it about a year ago, I switched from a 7980 with bad geo to a 7950(cause the 7980 wouldn't fit originally) with good geo. I haven't missed the 7980 yet! Can't wait to hear what you think about it, after you get it on the rocks! |
Re: Upper link plates 1 Attachment(s) Barrys Carbon plates are really nice. I run a hose clamp around the input bearing but there's other options for more mounting points. I get zero flex out of this. |
Re: Upper link plates I like the setup, it works alot better than having the servo sit flat on top of the plate. Sent from my SM-G900V using Tapatalk |
Re: Upper link plates It's not a bolt on part but the final outcome is worth every minute used to make shit work. I'll never go back to a traditional setup unless I plan on selling the rig. |
Re: Upper link plates I would like to use the same set up on scale, but with rules and regs that's a no go, lol Sent from my SM-G900V using Tapatalk |
Re: Upper link plates 100% legal It's still axle mounted. There's no other points of mounting outside of that. |
Re: Upper link plates I'm not taking any credit for this, I saw something like this, tweaked it to work for my setup, so it's a 1 off. Sent from my SM-G900V using Tapatalk |
