Thread: which gear?
Old 08-25-2007, 10:02 AM   #1
Default which gear?
Which motor pinion/gear required/recommended when using the Holmes Crawlmaster with the Axial AX-10?
Also - is there a motor mount required for this setup? If so - recommended vendor?
thanks in advance for the right answer
chris
cwkoehler is offline   Reply With Quote
