Thread: Transmission and driveline help
Old 11-19-2007, 08:29 PM   #1
Default Transmission and driveline help
hey guys. I am using an ax10 tranny in my sw3 build and was needing some help. I want to use my wk axles and was wondering what drivlines to get. i tried to use my traxxas ones, but the uotput shaft on my tranny broke. My spur gear also hit the yoke so im kinda in a bind here. I was wondering if there is yokes and drive shafts that i can get to fit the tranny without having to wait for the stock ones to be available? I was also wondering if there is any way to get some more output shafts? I tried to search but couldnt find anything. Thanks alot.
juststartin is offline   Reply With Quote
Old 11-19-2007, 08:37 PM   #2
get traxxas long shafts http://www.ckrccrawlers.com/shop/ind...roducts_id=445
Dickie691986 is offline   Reply With Quote
Old 11-19-2007, 08:39 PM   #3
i have those shafts. i need to get yokes that will not hit the spur gear and new output shafts.
Old 11-19-2007, 08:42 PM   #4
TEAM MODERATOR
Reflection's Avatar
Well,you could just buy a tranny and have pleanty of spares if you have any other issues RCP Crawlers Axial AX10 Transmission kit
Reflection is offline   Reply With Quote
Old 11-19-2007, 08:47 PM   #5
if i buy another tranny, which yokes should i get so they will clear the spur gear?
Old 11-20-2007, 06:35 AM   #6
binaryterror's Avatar
What spur are you using? The stock Axial is 87t and it works fine as is with Axial yokes or Traxxas yokes.
Buying the Trans seperate does not include the Spur nor the yokes, BTW.
binaryterror is offline   Reply With Quote
Old 11-20-2007, 04:11 PM   #7
i have the stock spur they yokes hit my spur. i must have the wrong ones. i think im goin to get the metal replacement ones.
