Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Heritage Crawlers > Axial AX10 2nd-gen
Thread: 3s too much?
Old 05-27-2012, 07:23 PM   #1
Default 3s too much?
I put my MMP with brushless motor in.....still on same battery pack and I have broke two front drive lines...
sandman is offline   Reply With Quote
Old 05-27-2012, 07:31 PM   #2
What motor?
nstn8 is offline   Reply With Quote
Old 05-27-2012, 08:23 PM   #3
Default Re: 3s too much?
novak 13.5 crawler
Old 05-27-2012, 11:14 PM   #4
yeah 3s on the stock drivelines is rough. i ran it in my wraith and had problems twisting them. you have a couple options, MIP shafts will fix it forever, or you can insert a piece of all thread into the male side of the stock driveshaft and it helps keep it from colapsing and twisting. it will still twist the splines, but it makes the stock plastic shafts alot tougher.
hoghead5150 is offline   Reply With Quote
Old 05-27-2012, 11:25 PM   #5
Get a 6mm tube or an axial aluminum link and slide it into the center of the driveshaft. Cut it to length. It will keep from twisting the shaft like a pretzel.
Propane is offline   Reply With Quote
Old 05-28-2012, 08:34 AM   #6
thanks!
Old 06-19-2012, 07:03 PM   #7
Natedog's Avatar
Or a peice of 0.258" CF tube cut to length and CA'ed into the male shaft, works good but may not be enough for the motor mentioned above lol.
Old 06-19-2012, 10:02 PM   #8
No idea what I'm doing
I'm running 3s with a 35t. Snapped the front driveshaft, so I did this...no problems so far:
http://www.rccrawler.com/forum/axial...ml#post3765684
C*H*U*D is offline   Reply With Quote
