Trevinator's AX10 RidgeCrest This is my crawler......... It started as a box stock AX10 RidgeCrest RTR. Then I modded it! :smt023 http://i57.photobucket.com/albums/g2...rest1Front.jpg http://i57.photobucket.com/albums/g2...rest2Front.jpg http://i57.photobucket.com/albums/g2...eCrest3Top.jpg http://i57.photobucket.com/albums/g2...ak35t13_87.jpg http://i57.photobucket.com/albums/g2...Crest5Back.jpg http://i57.photobucket.com/albums/g2...Crest6Back.jpg http://i57.photobucket.com/albums/g2...est7Bottom.jpg http://i57.photobucket.com/albums/g2..._5685mh72v.jpg http://i57.photobucket.com/albums/g2...ShockSetup.jpg As it sets right now...... The only stock pieces are just that.....pieces... -Stock trans - until it fails -Stock axles - soon to have overdrive/underdrive HD gears -Stock Ae-2 speed control Receiver/Radio - until they fail -Stock Rims - soon to be replaced -Stock heavily modified Ripsaw Tires - soon to be replaced Everything else is custom or at least modded..... -Hitec HS-5685mh servo 7.2v digital -Custom Servo Guard -Novak 35t motor and 13/87 pinion/spur -Integy AX10 Tube Chassis -Traxxas Revo Rod ends on custom suspension links -Traxxas Revo Rod ends, Integy Link/shock mount on Custom Steering Links -SCX10 Trans mount -Venom Creeper Shocks 30wt, internal/external springs for semi droop suspension -Custom Chassis Skins -Deans Connectors And I still need a Castle BEC to fully power my servo..... |
Re: Trevinator's AX10 RidgeCrest Nice it looks good! "thumbsup" |
Re: Trevinator's AX10 RidgeCrest Just picked up some axial rockster beadlocks and some HB white rovers!!! "thumbsup" Bye Bye Ripsaws!:flipoff: |
Re: Trevinator's AX10 RidgeCrest I can't believe no one noticed my number.......................:flipoff: |
Re: Trevinator's AX10 RidgeCrest Got out last week for a little crawl......Pre Rovers........ http://i57.photobucket.com/albums/g2...evDSCF0027.jpg http://i57.photobucket.com/albums/g2...evDSCF0025.jpg http://i57.photobucket.com/albums/g2...evDSCF0024.jpg |
Re: Trevinator's AX10 RidgeCrest Nice truck man. What all is left of the ridgecrest on it I just wondering? |
Re: Trevinator's AX10 RidgeCrest Thanks! The only stock pieces are just that.....pieces... -Stock trans - until it fails -Stock axles - soon to have overdrive/underdrive HD gears -Stock Ae-2 speed control Receiver/Radio - until they fail |
Re: Trevinator's AX10 RidgeCrest what length did you use on the links? |
Re: Trevinator's AX10 RidgeCrest I have changed my links.......twice now....and still havn't measured them.:roll: I have killed my servo....... how is Hitech's Warranty service???? |
Re: Trevinator's AX10 RidgeCrest servo killer! 8) I killed my stock servo too - replaced it with a hitec 7950 - now my servo keeps wanting to escape! After 10 to 15 mins of run time I have to stop and tighten all the servo screws... So did you make your own custom servo mount? It looks beefy. "thumbsup" and sorry I can't shed any light on HT's customer service - haven't had a need for it - yet... Cheers, Todd |
Re: Trevinator's AX10 RidgeCrest I soon will have an opinion on their service......but for now....:roll: Anyways, yeah the stock servo mounts are plastic and keep loosening off. A little dab of CA glue held for quite a while but still loosened off.... I think aluminum ones are needed..... My guard is just some 1"x1" aluminum angle cut with a hack saw, drilled in my drill press, and hand filed smooth.......it helps hold the servo by clamping it between it and the mount thus eliminating the chance of servo ears being ripped off. "thumbsup" |
Re: Trevinator's AX10 RidgeCrest Very cool!! How are you Creeper shock caps holding out? I popped the caps off my Creeper shocks right away and safety wired them on. |
Re: Trevinator's AX10 RidgeCrest They are holding up great.....so far.....;-) I have to replace the diaphragms in two of them.......but I am only running enough oil in them to lube em anyways........... LHS has a complete rebuild kit for them in stock right now so I may pick it up and rebuild em right. Or just keep running them.....:flipoff: I should take some more recent photos.................. |
Re: Trevinator's AX10 RidgeCrest Just ordered a whole lot of aluminum goodness! A new SAVOX servo, BEC, and over/underdrive gears! So once it all arrives I will be posting up pics of the upgrades!!! |
Re: Trevinator's AX10 RidgeCrest Sweet, keep us posted! Cheers Doc |
Re: Trevinator's AX10 RidgeCrest Quote:
Re: Trevinator's AX10 RidgeCrest The rocksters are to wide. I wish they were narrower too. They are for the AX-10 offset, not Wraith/Ridgecrest offset. I added some memory foam rings I made on top of the stock foams, much better now. |
Re: Trevinator's AX10 RidgeCrest Do you have bends on your upper suspension links? They look straight to me. I made custom lower links on mine and attempted to bend the uppers but I think I need thicker ID tubing, or get some stainless (I used aluminum). |
Re: Trevinator's AX10 RidgeCrest Parts arrival update........."thumbsup" RPP Boxart. http://i57.photobucket.com/albums/g2...psfeb835f1.jpg 500oz Savox 1230sg and Spectrum voltage protector. http://i57.photobucket.com/albums/g2...ps2c4f8edf.jpg Pile of AsiaTees goodness. http://i57.photobucket.com/albums/g2...ps0c695454.jpg TopCad Wraith offset rims. http://i57.photobucket.com/albums/g2...psbb453646.jpg TopCad Knuckles, C-hubs, Lockouts, and servo mounts http://i57.photobucket.com/albums/g2...ps686eee2e.jpg TopCad CVDs ......we will see how long they last...... http://i57.photobucket.com/albums/g2...ps272c42de.jpg Free AsiaTees Golf Shirt. http://i57.photobucket.com/albums/g2...psa3cddc67.jpg |
Re: Trevinator's AX10 RidgeCrest More Parts.............:ror: Hobbypartz had a wicked sale on............ Thunder AC6 Charger. http://i57.photobucket.com/albums/g2...ps6a6dab1c.jpg GensAce Eco Lipos ($3 each:shock:). http://i57.photobucket.com/albums/g2...psf6cb4dd5.jpg Group shot with Lipo Bag. http://i57.photobucket.com/albums/g2...ps97d6645e.jpg |
