Gearbox problems.... Second time out with the Ridgecrest today,had fun for a while.Front wheel drive stopped,and it started clicking.Pulled the trans apart,no lube!Three little screws fell out,plastic gear and case shavings everywhere....Any advice on what to purchase,stock/aftermarket??? |
Re: Gearbox problems.... Robinson Racing metal gears, super strong and fairly priced"thumbsup" |
Re: Gearbox problems.... I don't know if the Ridgecrest transmission is like the SCX-10 or the Wraith. If it's like the SCX-10, buy Robinson Racing #1541 & #1542. Put those in (with enough lube), close it up, and forget about it. |
Re: Gearbox problems.... What should i use for lube?Anybody know what Robinson gears will fit? |
Re: Gearbox problems.... I gave you the part numbers for the SCX-10 tranny gears. I think that is the transmission the Ridgecrest runs. Grease is a whole other thread all together. I use Mobil 1 Synthetic (red) grease. |
Re: Gearbox problems.... LHS had the lower diff gear in stock only,picked it up for now.Cleaning,greasing and putting it back together for now. |
Re: Gearbox problems.... Go ahead and order the idler gear. Those two metal gears will eat that little idler for lunch. If you get into a bind, don't throttle out. |
