03-01-2016, 03:15 PM | #1 |
Newbie Join Date: Sep 2015
| Ar60 half shaft.....
So I've been running some concept/prototype builds, and well the stock ocp ar60 half shafts are crap. Were and who makes the best half shaft for the ar60? I need some bad dudes.....so lay some concept down if you have any insight on the internal half shafts. Sent from my SM-G360T1 using Tapatalk |
03-01-2016, 03:23 PM | #2 |
| Re: Ar60 half shaft.....
I need to handle 1/8 monster X...... Sent from my SM-G360T1 using Tapatalk |
03-01-2016, 05:34 PM | #3 |
Try to Bend it Join Date: Aug 2009 Location: Perth Australia
Vanquish VVD
03-02-2016, 08:03 AM | #4 |
Good luck. The design is very limited due to the restrictions of the housing. Either a stock universal or you need to get better axles like the 1808's. |
03-02-2016, 10:53 AM | #5 | |
| Re: Ar60 half shaft..... Vvd's are nice but you're limited on turning ability. They wear out just like a universal will and the repair parts cost as much as just buying universals in the first place. Quote:
Yup, the housing is a limiting factor for sure. You can only fit so much shaft between the screws for the lower link mounts. | |
Ar60 half shaft..... - Similar Threads | ||||
Traxxas Steel diffs and half shaft ????'s | PIMPNROCKS | Newbie General | 1 | 12-05-2007 11:54 PM |
Traxxas half shaft question | Stallion1967 | Newbie General | 8 | 04-09-2007 08:49 AM |
Yoke and Half shaft question... | tecnica2001 | Tamiya TLT Crawlers | 2 | 10-05-2006 08:18 AM |
