Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Heritage Crawlers > Axial AX10 2nd-gen
Thread: AX10 Deadbolt
Old 12-27-2016, 02:36 PM   #1
Default AX10 Deadbolt
Hey guys, got a heavily used ax10 deadbolt and I was trying to sell it but no luck so I've decided to keep it. Thinking about doing it up a little and was just wondering if what I'm thinking of doing is good. Has old aluminum links on it that don't like to slide over anything so I'm thinking of replacing them? Also, was looking for a body that would fit on it because the one I have is rough and definetly needs to be replaced at some point
Thanks for the help I know I'll get some good responses
RatBoy D is offline   Reply With Quote
Old 12-27-2016, 07:36 PM   #2
Default Re: AX10 Deadbolt
Check out the sticky at the top of the sub forum for body ideas
Mike Flea is offline   Reply With Quote
Old 12-28-2016, 09:50 AM   #3
Turn it into a Monster Bolt!
Pro-Line Transforms Axial Racing
kmnss is offline   Reply With Quote
Old 12-29-2016, 10:08 AM   #4
The Incision stainless Wraith full link kit would be a big step in the right direction.
SCREAMER is offline   Reply With Quote
Old 01-15-2017, 03:09 PM   #5
I stuck a pro-line 1992 Jeep Grand Cherokee body on my ax10 deadbolt I bought new. I got sick of how ugly the stock body was, there was a lot of trimming involved tho, I painted mine orange I just love the color orange.
My truck is built up as follows:
-Axial steel center trans gear set
-Pro line tsl xl 2.2" s on axial black rockster beadlocks
-STRC aluminium black steering links
-1230sg servo
-Axial universals
-Hobbyking sensorless brushless 100amp esc(yes total overkill, the 45 amp version wasn't available) with a 3300kv 3650 motor. It is setup just so, that the timing is set to low and the punch is set to low, and full drag brake, all of this is able to be setup via the esc... It actually works pretty good for crawling
-3s lipo power
-Next mod that is on the way is traxxas big bores
-Custom steel 4 links with Traxxas 5347 revo rod ends and 8-32" threaded rod sheathed in 1/4" steel tube.
Lol the first mod is to move the battery tray to the front
Spencecrawler is offline   Reply With Quote
AX10 Deadbolt - Similar Threads
Ax10 deadbolt facelift Obscenerc Axial AX10 2nd-gen 2 09-08-2016 06:17 PM
AX10 deadbolt body on SCX10 deadbolt BrianP Axial SCX-10 3 11-08-2015 04:51 PM
ax10 deadbolt body macz Axial AX10 2nd-gen 0 05-19-2015 03:15 PM
Axial Ax10 Deadbolt and AE-5 Geck0Jeep Axial AX10 2nd-gen 2 10-01-2014 08:54 AM
