Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Axial Brand Scale Rock Crawlers > Axial Capra
Thread: Broken parts so far?
Old 11-19-2019, 02:43 PM   #1
Default Broken parts so far?
Hey. Anyone broke their rig yet? I got an axial capra last month. Equipped with a holmes hobbies stubby 2700+ micro x on 3s. Hitec servo on castle bec at 8v pushing 400+ ozin. so far I have broken a tie rod end, and blown up the ball bearing in the rear pumpkin on the ring gear side. Anyone else break parts yet? Hopefully the rear "diff" doesn't become an issue and was just a fluke. I'm working on overdrive front portal gears made using rr hardened pinions with machined slots and square drive. I also want to kill my own servo mount out of aluminum. I may need to get some clamping wheel hexes since my stub shafts are already distorting pin holes from the torque of the stubby!
MCRIPPPer is offline   Reply With Quote
Old 11-19-2019, 07:25 PM   #2
Default Re: Broken parts so far?
Were parts easy to get?
Bambooi is offline   Reply With Quote
Old 11-19-2019, 07:29 PM   #3
I don’t feel I’m overly hard on my equipment but I haven’t broken anything. I’ve replaced the servo mount with an aluminum SS version, SS MIP driveshafts and replaced the hex’s with a set of the 8mm KNK brass version. I even wheeled it this weekend at Moab without incident.
Lashlee is offline   Reply With Quote
Old 11-19-2019, 08:00 PM   #4
Gold Star Baby!
Topher Builds's Avatar
Same. No issues at all, I’ve been running the spektrum micro servo at 7.4v as well and it’s been holding up.
You could probably build one from scratch (not recommended) with the parts available on RPP.
https://www.rpphobby.com/SearchResul...arch=Axial+UTB
Topher Builds is offline   Reply With Quote
Old 11-19-2019, 09:35 PM   #5
I snapped my front axle housing. Axial had a new one in my hand within 5 days. Otherwise no problems.
punkindrublik is offline   Reply With Quote
Old 11-19-2019, 09:57 PM   #6
I haven't broken anything but the hearts of those that couldn't follow el chivo.
WHITE-TRASH is offline   Reply With Quote
Broken parts so far? - Similar Threads
Broken parts Alexg89 Micro Scale Rigs 10 07-12-2019 07:52 PM
First broken parts. anuthabubba Losi Mini-Rock Crawler 3 05-22-2013 07:34 PM
Parts, Some New ,some Broken twisted Tamiya TLT Crawlers 3 04-17-2007 02:03 PM
