03-15-2020, 09:05 AM | #1 |
Newbie Join Date: Mar 2020 Location: Bridport
| Front axle catches while turning
Just got the 1.9 capra a few weeks ago. I love the way it operates but last night i noticed it was kind of "catching while going really slow and its way worse while turning either way. Just wondering if anyone has either had this happen yet or if anyone has a quick solution before i tear it apart
03-15-2020, 06:01 PM | #2 |
Rock Stacker Join Date: Feb 2017 Location: Merton
| Re: Front axle catches while turning
Rtr or a kit?
03-17-2020, 09:59 AM | #3 | |
| Re: Front axle catches while turning Quote:
What kind of surface were you on? Locked diff rigs will stutter like that at full lock on high traction surfaces, I.E., pavement, asphalt, real grippy rock. | |
03-17-2020, 11:57 AM | #4 |
Quarry Creeper Join Date: Feb 2018 Location: East otis
I don't have a capra, but i saw a video by john holmes showing the tires oscillating under slight throttle, but only on the ground, not in the air with no resistance. He said the diff needs to be shimmed on them. Maybe try to do that and see if its any better. Sent from my SM-G970U using Tapatalk |
03-17-2020, 12:11 PM | #5 | |
Gold Star Baby! Join Date: Dec 2017 Location: Las Vegas
03-17-2020, 12:54 PM | #6 |
There is also a natural resistance that universal joints experience while turning, go at a steady speed and turn then watch the rig slow down a bit. This is just the nature of a U joint, whether this is whats happening or not I cant say but its worth noting. I would check this by removing the driveshafts from the transfer case then feeling the front and back individually while turning it by hand. Either keep in mind that the driveshaft typically pulls the pinion away from the ring gear (so pull as you spin) or leave the driveshafts attached to the pinions. If it feels notchy it needs shimming, if it feels smooth shimming will not help. Last edited by HumboldtEF; 03-17-2020 at 12:56 PM. |
Tags |
capra front portal axle |
Front axle catches while turning - Similar Threads | ||||
Front end shaking during turning. | Al bundy | Axial SCX10 II | 5 | 03-13-2018 01:03 AM |
Ascended Front tires not turning | K10Crawler | Vaterra Ascender | 3 | 05-07-2017 07:51 PM |
Front end chatter when turning | Oldgreg | Axial SCX10 II | 10 | 11-03-2016 09:30 AM |
CVD front axle binding when turning | Odd-M | Axial SCX-10 | 9 | 08-19-2014 01:44 PM |
back wheels are turning before front? | tombs | Redcat Crawlers | 18 | 04-20-2010 10:05 PM |
