Capra VS410 chassis Nicely done man. Love that paint job! |
Re: Capra VS410 chassis Looking good man!! |
Re: Capra VS410 chassis Great looking build!"thumbsup" |
Re: Capra VS410 chassis Thank you guys. Sent from my SM-G965U1 using Tapatalk |
Re: Capra VS410 chassis Got some ssd portal weights and some brass inner wheel rings along with a couple scale accessories mounted up. I have an interior and a warn winch to install but I am digging this build.https://uploads.tapatalk-cdn.com/202...6c6255e0d2.jpghttps://uploads.tapatalk-cdn.com/202...d751645a17.jpghttps://uploads.tapatalk-cdn.com/202...3a846bb3e4.jpghttps://uploads.tapatalk-cdn.com/202...3c2b1a2017.jpghttps://uploads.tapatalk-cdn.com/202...ebf26f26d7.jpg Sent from my SM-G965U1 using Tapatalk |
Re: Capra VS410 chassis Mounted the winch. Need to drill or elongate a couple of the holes on wertymade bumper to get the two outer bolts in. Center ones lined up. https://uploads.tapatalk-cdn.com/202...01d7926ef1.jpghttps://uploads.tapatalk-cdn.com/202...6b65915763.jpg Sent from my SM-G965U1 using Tapatalk |
Re: Capra VS410 chassis Painted up interior today. Need steering wheel and driver. Not so good but it will work. https://uploads.tapatalk-cdn.com/202...640d9519c2.jpghttps://uploads.tapatalk-cdn.com/202...9fd78ee195.jpghttps://uploads.tapatalk-cdn.com/202...a8c18f8404.jpg Sent from my SM-G965U1 using Tapatalk |
Re: Capra VS410 chassis Makeshift flex ramp. Rig is ok but I think it should have more. Tried flipping shocks upside down for added lower CG even though it's so minimal but what the heck, worth a try. I can't get the shocks laid over anymore because the mounts. Anyone got and ideas or where to get different mounts for vs410 chassis? https://uploads.tapatalk-cdn.com/202...fe9c9811bc.jpghttps://uploads.tapatalk-cdn.com/202...ca9d11ef10.jpghttps://uploads.tapatalk-cdn.com/202...4ee2482413.jpg Sent from my SM-G965U1 using Tapatalk |
Re: Capra VS410 chassis Not sure if it's what you are looking for, but IERC makes a set of VS4-10 mounts: https://iercscaler.com/shop/ols/prod...0-shock-towers |
Re: Capra VS410 chassis Quote:
Re: Capra VS410 chassis Got some goodies in the mail today. IERC shock towers, drop in bed and head rack. https://uploads.tapatalk-cdn.com/202...5fca79183a.jpg Sent from my SM-G965U1 using Tapatalk |
Re: Capra VS410 chassis Nice! I'm working on getting my cab body ready to paint, should have most of it done this weekend, I'm real anxious to see how all this stuff works out. |
Re: Capra VS410 chassis Good stuff shinook. I need to play with shock angle for ride height and maybe take out the internal pen springs trick. But everything went together smooth and looks good. Cleaned up the back of my truck for sure. Thanks again for the link to the partshttps://uploads.tapatalk-cdn.com/202...bfa523eb3e.jpghttps://uploads.tapatalk-cdn.com/202...4eceb15da2.jpghttps://uploads.tapatalk-cdn.com/202...72f0e7a5c3.jpg Sent from my SM-G965U1 using Tapatalk |
Re: Capra VS410 chassis Had the truck out over the weekend and broke some teeth off a top portal gear. A small rock wedged between portal and inside rim. I hammered the throttle and pop. So I ordered the Team Garage Hack portal gears from Super Shafty and look forward to getting it fixed. I got the wild overdrive for front and stock replacement for rear. Hope it works . Anyone have these on their capra? How do you like the overdriven front?https://uploads.tapatalk-cdn.com/202...b62eed6727.jpg Sent from my SM-G965U1 using Tapatalk |
Re: Capra VS410 chassis Got some Wertymade rock sliders and did some drilling / thru bolting to mount them up. Also cleaned up the wiring and relocated the winch controller and reciever. Old Cactus Jack is in as a driver figure. Also fixed my broke portal gears with the TGH gears. Front is wild overdrive ratio and rear is stock ratio. Can't figure out how to post video showing overdriven front. Hope to test it today at Rock city Park Mt. Diablo. Does anyone run this portal gearing? How do you like it?https://uploads.tapatalk-cdn.com/202...a3009efad7.jpghttps://uploads.tapatalk-cdn.com/202...d048b75303.jpghttps://uploads.tapatalk-cdn.com/202...46c4226198.jpg Sent from my SM-G965U1 using Tapatalk |
Re: Capra VS410 chassis Got out to play yesterday for a few. Everything went ok except the esc kept thermaling. Mamba micro x is not very good for this truck apparently. I guess I will buy the mamba x or rob it from my bomber for now. Frustrating for surehttps://uploads.tapatalk-cdn.com/202...f04d404b64.jpghttps://uploads.tapatalk-cdn.com/202...e36912a17c.jpg Sent from my SM-G965U1 using Tapatalk |
