Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Axial Brand Scale Rock Crawlers > Axial RR10 Bomber
Thread: Rear upper links?
Old 12-16-2015, 05:03 PM   #1
Default Rear upper links?
Has anyone tried straight rear upper links. I've made my own all thread and tube before on scx's but have never tried to bend them. I wonder if straight links will work?
THUNDER PRO is offline   Reply With Quote
Old 12-16-2015, 05:25 PM   #2
Suck it up!
Duuuuuuuude's Avatar
Default Re: Rear upper links?
They should. Depends on how you've got them mounted at the skid.
Duuuuuuuude is offline   Reply With Quote
Old 12-16-2015, 05:29 PM   #3
Was going to use the standard revo rod ends and mount in the stock location.
Old 12-16-2015, 05:32 PM   #4
Suck it up!
You should be ok. Maybe a slight bend just because. Straights will definitely work up front btw...
Old 12-16-2015, 05:45 PM   #5
Yes I was planning on making my own lowers and I have wraith bent front uppers so good to go there. The best I have found to use is K&S stainless tubing over all thread with the revo rod ends. The K&S is the strongest of all the other tubing in my testing ,although it is a few pennies more expensive.
Old 12-16-2015, 05:58 PM   #6
Suck it up!
I meant the front uppers can be straight. No interference at all.
You're going to want a little inward bend on the front lowers if you plan to run universals or cvs. At full lock mine will hook hard on the stock lowers.
Old 12-16-2015, 06:10 PM   #7
Thanks for the help. Love some of those blue wheels,might have to send some money your way after you enjoy your holidays.
Rear upper links? - Similar Threads
Titanium rear upper links. Fordfreak95 Axial Yeti XL 15 01-26-2015 04:47 AM
rear upper links will8863 Axial Yeti 15 01-14-2015 12:34 PM
Rear upper links mydoddy69 Vaterra Twin Hammers 0 04-02-2013 02:29 PM
Rear upper links motorman Axial XR10 7 09-30-2010 09:47 PM
