08-22-2017, 08:40 PM | #1 |
Newbie Join Date: May 2014 Location: Missouri
| Suspension rod ends
Hey all, The stock rod ends on the kit Bomber...they keep breaking on my daughter's vehicle. I've replaced the front ones that mount under the shocks a few times. The last two times they have broken at a local A-Scale track where we jump it a bit. Are the Axial ones just that weak? These are the Axial rod ends that are bent at a 45 angle, straight suspension links. Do I need to tweak the suspension or what? It is stock now. Doesn't bottom out when jumping. Small jumps. Should I opt for the Inscision links that use the straight Traxxas ends? Opinions wanted. Thanks. |
08-22-2017, 10:32 PM | #2 |
Quarry Creeper Join Date: Mar 2015 Location: Woodland
| Re: Suspension rod ends
I personally have Ti Vanquish link with the traxxas rod ends on them. I break them from time to time. Maybe every 5 packs I'll break a rod end, usually in jumping or big roll overs. Its just the nature of the beast. I'm running holmes hobbies brushless FYI. I know its not a critique of the stock rod ends, but just letting you know it still happens on the after market stuff. |
08-23-2017, 04:38 AM | #3 |
Quarry Creeper Join Date: Oct 2016 Location: Littleton
Since I started using the RPM rod ends, I have not broken one. I am running these on 2 scx10.2s, my Bomber and my Slash 2wd with 2.8 tires and they just don't break. Sent from my SM-N910P using Tapatalk |
08-23-2017, 06:51 AM | #4 |
Rock Stacker Join Date: Jan 2016 Location: farmington
cheap metal ends was a must for me, work great
08-23-2017, 07:39 AM | #5 |
RCC Addict Join Date: Aug 2008 Location: Paulina
I switched my Bomber to Revo ends. Far stronger than stock Axial ends.
08-23-2017, 12:06 PM | #6 |
Rock Stacker Join Date: Sep 2016 Location: USA
I broke a few stock ends at first but I was not running the set screw all the way into the end first before I put in on the link. Since I've started running the screw in til it bottoms out I haven't broke one. Having said that I do plan on changing the links so I can use aftermarket "straight ends" because the stock end and ball wear out really quick and are not cheap since you have to buy the whole parts tree for only a couple ends.
08-26-2017, 02:16 PM | #7 |
Thanks everyone. I'll change out what I have then probably switch to those Revo ends posted above. LHS should have them. |
08-27-2017, 11:34 AM | #8 |
| Re: Suspension rod ends My brother speaks very highly of RMP's compounds, he says better and more durable than the traxxas rod ends. I am going to try the RPM's after i break all my Traxxas rod ends.
Suspension rod ends - Similar Threads | ||||
Rod ends for homemade CC-01 suspension links | nigelw | Tamiya XC/CC01 | 0 | 05-17-2012 05:46 AM |
Drilling Holes into Delrin rod for rod ends | FDAapproved | Losi Mini-Rock Crawler | 10 | 02-13-2009 03:44 PM |
Lower suspension rod ends | Drvnbeing | Losi Mini-Rock Crawler | 11 | 01-12-2009 02:56 PM |
TLT upper suspension stays - biggest rod ends? | HndsWthtShdws | Newbie General | 3 | 02-29-2008 08:55 PM |
