03-23-2009, 08:32 PM | #1 |
Quarry Creeper Join Date: Dec 2008 Location: Aurora Colorado
| Scale shocks
I am in the process of building a 2.2 SCX-10 with an HPI Bronco Body. I am planning on using the Scale shocks with internal springs from rc4wd. With 2.2 should I go with the 100mm shocks or should I go with the 90mm shocks? http://rc4wdstore.com/product_info.p...roducts_id=692 I was thinking of 100 due to the larger tires but thought someone out there may have some insight on this. Thanks, TL |
03-23-2009, 09:38 PM | #2 |
Quarry Creeper Join Date: Nov 2007 Location: nanakuli
i'm running the rc4wd dual rate scale shocks on mine. i'm running the 90mm ones. they will look more scale on this truck in my opinion. only cause it's 4 linked. i honestly think should have went with the 100mm ones. they ride height as dropped a little with these shocks. they are very nice though. i only went with these size shocks cause a saw a few people here that had them. i would run 100mm shocks if i were you. i compared the 90mm dual spring shocks to the stock shocks and they are shorter.
03-24-2009, 07:31 PM | #3 |
Thanks Keala I will get the 100mm
03-25-2009, 03:40 PM | #4 |
03-25-2009, 06:29 PM | #5 |
Can you remove the springs and put softer ones in? When thinking about my full scale rig and the coils it uses they are very stiff as well. So maybe if you can remove the springs and use it more like a shock absorber than have the coil seperate like a 1:1 rig than it would work well. |
03-25-2009, 07:24 PM | #6 |
Rock Crawler Join Date: Aug 2007 Location: usa
use tlt shock springs
05-11-2009, 09:28 AM | #7 |
Pebble Pounder Join Date: Mar 2009 Location: Whittier
Hate to bump a old post but also thinking of changing to a scale shock any of you Guys have pic's with them mounted on the SCX |
