09-30-2009, 04:54 PM | #1 |
RCC Addict Join Date: Nov 2008 Location: never been
| Jootz SCX tubework bit the bullet by trying my hands at brass brazing, supplies are cheap and plentifull at lowes so pretzel tubing dont hurt as much plus its easier to bend brass rods(solid 3/16), i think,,, cut, bent and brazed my first stinger- its not done yet but i stopped after need of a better tubing bender. i thought my ghetto fabbed bender was titays but not. heres a couple pics, any help and or info on this bending and brazing will be appreciated, specially how to calculate bending length as that still has me zoomed. the stinger will be attached by M3 nut and bolt, holes are done just didnt have the hardware. WIP |
09-30-2009, 06:18 PM | #2 |
RCC Addict Join Date: Jul 2006 Location: Pasadena
don't poke yourself in the eye with that stinger... it looks pretty good so far. |
09-30-2009, 06:29 PM | #3 |
Rock Stacker Join Date: Sep 2009 Location: hampton
| thats a nice nice work......i think ineed to try that one also....what do u need to connect those tubes? |
09-30-2009, 06:52 PM | #4 |
I wanna be Dave Join Date: Jun 2007 Location: Canada, eh.
Looking good for your first time Ernie. Stinger could use a little more bracing, it'll get tweaked in a fall the way it's set up currently, but otherwise good job.
09-30-2009, 08:51 PM | #5 |
Looks like flux is needed to get the braze to flow in the joint and not build up.
09-30-2009, 09:03 PM | #6 |
Newbie Join Date: Aug 2009 Location: Winchester, Ohio
Great start. Keep it up. I'm gonna have to try my hand at tube work before to long.
09-30-2009, 09:28 PM | #7 |
I wanna be Dave Join Date: Jun 2004 Location: San Jose
I think the stinger is longer than the hood. The stinger really only needs to be longer enough to keep the hood untouched in a roll-over. Or to keep the rig from flipping forward when descending off a ledge.
10-01-2009, 12:19 AM | #8 | ||||
gonna go get proper supplies tomorrow and have this figured out. i have to since there`s still lot of bending,bracing and brazing before im finished with this rig build Quote:
thank you guys. keep the input coming, im looking at a full roll cage with the top chopped on this rig and i just barely touched the surface. | ||||
10-01-2009, 07:32 AM | #9 | |
I wanna be Dave Join Date: Oct 2006 Location: Martinsburg WV
The problem with brass and plumbers solder is you can easily overheat your joint. Not so much of an issue if your work is securely jigged, but if you're doing the hold it with one hand and heat it with the other routine you'll have to wait a while (w/o moving your piece) for the solder to cool enough to solidify. How long depends on how far above it's melting point you heat it. I've realized steel has one distinct advantage over brass - it's a ferrous metal, which allows you to use magnets for jigging purposes. Quick and easy. Brass has to be clamped or wired in place. The advantage of brass and plumbers solder is it's easy to find and inexpensive to work with. You can sometimes tin both brass pieces (like you would doing electrical work) and then do a quick hold-and-heat w/o any jigging. I've tried this w/ Harris Safety-Silv also, it seems to work the same. You just have to watch the heat, so it cools as rapidly as possible once its done. Looks like a good start! A little on the tall side maybe, but thats up to you. Now that you have this much together, it gives you a much better visual reference and you can start adding more tubing/rod to flesh it out some and brace it up | |
10-01-2009, 08:36 AM | #10 | |
thanks for the comments Big Mike, i fell asleep in my den just poring over pics of tubed rigs and brazing WIP here sponging everything in. i will do another stinger but apply what ive learned so far, reason i went with brass is to keep cost down while on matriculation, if i feel ive picked up enough then maybe move to MAPP and fuel line. im still having a hard time bending with measurements. that front stinger do look like a clothes line/LOL | |
10-01-2009, 08:53 AM | #11 |
I wanna be Dave Join Date: Jul 2008 Location: appleton
I will be bringing my scx to work now that we are slowing down and get my service techs something to do dam goverment work.
10-01-2009, 09:17 AM | #12 | |
10-01-2009, 09:26 AM | #13 | |
i hear you, as much as i love multi-tasking this new skill im trying to learn has me stumped-for now. but from admiring other peoples tube work to now being able to braze my own stuff just feels so good. and i am jotting down notes | |
10-01-2009, 03:28 PM | #14 |
personaly i think its too tall and the angle that it goe out at is off and the top could be closer to the body
10-03-2009, 09:43 AM | #15 |
10-09-2009, 04:36 PM | #16 |
| burns&blood update did work on some free time and got to this. darn brazing is not easy, so is bending. im still a noob after burns and blood/LOL the front stinger is an iffy- like its not meshing with the looks or sumthin, the cage is bolted on to the chassis. im mulling if i should take the whole top off or leave the front windshield. also what to do with the rear trunk with the top off. suggestions be most welcome, thanks for looking |
10-09-2009, 05:02 PM | #17 |
dudz you doing great.......... |
10-10-2009, 06:13 AM | #18 |
I wanna be Dave Join Date: Sep 2006 Location: Stuck on a Rig in the middle of nowhere Utah.
I think the cage came out great . Looks like your brazzing has gotten better too. The front stinger does look a little off, but I am not critisising you at all. It is better that I have done. Keep us posted.
10-10-2009, 06:44 AM | #19 |
I wanna be Dave Join Date: Apr 2009 Location: Unnecessary Surgery Land
Roll cage looks great
10-10-2009, 08:16 AM | #20 |
| thanks thanks, that stinger was inspired by the truggy builds here/LOL. i cleaned-up on the brazing before the pics, those on the pics been dremeled to death. using brakeline on the top bars i found its easier to braze than solid brass rod but might not be as rigid. |
