Thread: Whats needed to extend the wheelbase?
Old 09-19-2010, 10:17 PM   #1
Default Whats needed to extend the wheelbase?
Hey guys. What parts are needed to Extend the scx10 11.4 wheelbase to the honcho 12.3 wheelbase? A list with part numbers would be great. IM looking at doing this sometime in the next few weeks. and figured it be cheap buying the parts seperate then buying the kit axial has out
PontiacGT201 is offline   Reply With Quote
Old 09-19-2010, 10:38 PM   #2
The honcho uses 98mm Lower links in the front and 106mm links in the rear. Although buying the aluminum pieces would be easiest, the cheapest route would be to built your own using some all thread and rod ends. Do a quick search for "custom links" and you should be set. But if your set on the aluminum pieces, go to Axial's website and download the Honcho kit manual. All the part numbers are in there for you.
2JSC is offline   Reply With Quote
Old 09-19-2010, 11:06 PM   #3
hmm ok, ill check that out.
dang didnt even think about checking the Honcho Manual. thanks
Old 09-19-2010, 11:45 PM   #4
Go here and get part numbers for either longer links or posts and allthread pieces to stretch it out to whatever length you need
http://www.axialracing.com/ftp/ax10o...s_spacers.html
Ty@Tekin is offline   Reply With Quote
