02-12-2011, 09:13 AM | #1 |
Rock Crawler Join Date: Aug 2010 Location: Salt Lake
| Anyone use a Dig as a FWD disconnect?
I am putting together a honcho one piece at a time. I got a used trans with a dig that I plan on running on the front as a disconnect sort of like a transfer case on a 1:1. Who has done this and what driveline mods would need to be done, I have the 12.3" wheelbase. I assume a set of MIP's won't work. It's my first scaler so I have no idea if it will work or not.
02-17-2011, 09:58 AM | #2 | |
Rock Stacker Join Date: Aug 2009 Location: Crawlarado Springs
02-21-2011, 07:40 AM | #3 |
I attempted to use the HR dig with an axial trans. First problem was the dig is too far out and hits the upper link mount/link. Second would be the driveshaft would be on too much of an angle and bound in all positions. I gave up on the 2wd for now until I can either make up a mount to move the trans back a bit, modify the frame to let is sit further back, or put the motor and trans up front and run a seperate transfer case.
02-28-2011, 05:15 PM | #4 |
Pebble Pounder Join Date: Aug 2009 Location: RuffNeck Build Lab.....
Just so you know doing this will not make it perform any different mainly cause the front axle is still locked. All you will end up doing is have a rig that turns even worse because the rig will be trying to push the frontend around instead of it pulling itself around. Just something to think about. |
02-28-2011, 06:32 PM | #5 | |
02-28-2011, 08:26 PM | #6 |
02-28-2011, 09:37 PM | #7 |
RCC Addict Join Date: Oct 2008 Location: PA
I ran a dig backwards. It was cool for about 10 minutes..... Crawler burnouts get old quick
