View Poll Results: What color next?
Go back to Maroon 5 31.25%
Stay at green 3 18.75%
Tan with black stripe 5 31.25%
Yellow with black stripe 3 18.75%
Voters: 16. You may not vote on this poll
Thread: Ford SCX10 build thread
Old 03-21-2011, 08:15 PM   #1
Default Ford SCX10 build thread
This thread will have pictures and videos of my truck when I get my computer fixed. Stayed tuned it will be a tubular rig!
Alright! Ive got a new computer! Here are some pictures
Then I decided to change the color
Now to put the stripe back on
Something screwed up so I had to do some sanding and repainting
Now the finished product
Hydro-Tank is offline   Reply With Quote
Old 05-22-2011, 09:15 PM   #2
What you guys think?
Old 05-22-2011, 09:51 PM   #3
Really nice truck. When I finally get my Scx10 I need to put a blue oval body on it. Where did you get that one with the grill and everything?
federally is offline   Reply With Quote
Old 05-22-2011, 10:00 PM   #4
U can get those at rpp. The cab,bed,grill,mirrors,wipers... Rpp has all u need for the 350... Btw nice truck man I personally like the maroon paint with black stripe better it looks more like a 1:1 with the maroon.. But that's my .02
J-bird
j-bird is offline   Reply With Quote
Old 05-22-2011, 10:55 PM   #5
Hey thanks you guys. Got any suggestions for it?
Old 05-22-2011, 11:40 PM   #6
No because I don't know jack about crawlers lol.
It would look cool with sideview mirrors tho! Oh and Leds!
Old 05-22-2011, 11:55 PM   #7
It has LED in the front lights but cant figure out how to connect them, now ya see I dont know jack about electric stuff.
Old 05-23-2011, 10:00 PM   #8
One plan I have for it would be to lower it. Like I was goin to widein the axel and lower the shocks and go with bigger tires. I just dont know where to get axel spacers. And would it be as simple as putting the axel spacers on and getting lower shocks and throwing on some 2.2s or somthing?
Old 05-24-2011, 08:09 AM   #9
U can always just droop ur shocks instead of getting shorter ones that way u won't loose any travel
J-bird
Old 05-24-2011, 08:32 AM   #10
What he said.
-- Sent from my Palm Pre using Forums
pixelnate is offline   Reply With Quote
Old 05-24-2011, 12:05 PM   #11
how do I do that?
Old 05-24-2011, 05:04 PM   #12
i don't like fords, but i like the bed! do you have any more pictures of how you built that bed around the roll cage?
Spiike is offline   Reply With Quote
Old 05-24-2011, 09:41 PM   #13
Today I went through my closet for some clothes that did not fit me, so I could send them to the Joplin area for the relief of the tornado deal. And found some scale stuff to put on the truck. I found a sleepin bag, .22 bullet cartrage that I painted red(like a toolbox), and a GI joe gun. Made the ''bungie'' cords me self, sorry bout the blue one, kind of messes up the radicalness.
Here ya go bud. If you do not see, there are tabs connected on to the cage,And I just simply drilled holes in the bed sides and put in some allen wrench screws to bolt them in.
If you guys got any questions feel free to ask. Now how about this drooping thing, what is it and what do I do?
Old 05-25-2011, 02:56 PM   #14
looks good, the bed came with the cab i take it? you just bolted it to the roll cage?
Old 05-25-2011, 06:54 PM   #15
ya.
Here in a little bit plans..
Ordering some 2.2 TSL Super Swampers
After finding out what the h e double hockey sticks drooping shocks is that will be done.
Finding information on how to widen the axles. Stay tuned. I might do some things in between those things.
Old 05-26-2011, 02:32 PM   #16
Almost there! Check out the new shoes! They are the TSL 2.2 Super Swampers I was talkin bout have not got to me yet but they will eventualy
Old 05-26-2011, 04:26 PM   #17
Originally Posted by crazyrccrawler View Post
ya.
i know most don't like integy, but they have those wheel extensions, they are
Integy EXT & 15mm Wheel Hub & Wheel Axle AX10
heres a link
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXUHH7
you might be able to find different company extensions, but theres an option for you
Old 05-26-2011, 04:34 PM   #18
heres a link
Right now I am trying to find any option there is haha. Thank you for finding that. So you think that AX10 things would fit on scx10? They look nice to me.
Also look at my new riimz,
Old 05-26-2011, 05:22 PM   #19
Yes they fit, my brother in law bought them for his dingo converted to honcho, he bought tsl 2.2 super swampers. then we bought axial 2.2 rock locker rims. the tires rubbed on the links. the extensions worked very well. till he bought rims with maximum widening offset. then he didn't need them anymore. The only problem with buying these, is if the rear is locked straight axle, you can't use these extensions (just the back). the only way you can use the extensions on the rear is if you have 4 wheel steer. if you look at the picture the rear extensions are the same as front with the cv joint cup. they still work great on the front however. just a heads up!
Most stuff that is built for ax10 does fit the scx10. depending on what you buy. like the axles and the transmissions are exactly the same. drive shafts are the same. most parts are interchangeable with the ax10. somethings you hvae to watch. like the bent links for the ax10 are missing a few peices to make it work on the scx10, you have to buy 2 sets of ax10 bent links to fit them properly on the scx10 to make it proper 4 link. the kit is built for ax10 3 link. my brother in law is running the bent links on the lowers, and had to use the stock plastic links for the uppers because the kit didn't come with the right parts for the upper links. buying a 2nd bent link kit would solve that problem. it has to do with the 3 link, and wanting to make it a 4 link.
if that makes sense to you.
Old 05-26-2011, 08:44 PM   #20
Ya that makes sence. But that also might be bad news, mainly because my rear might be locked
What happens if I would go head and put them on the back, even though they are locked?
