10-03-2011, 07:03 PM | #1 |
RCC Addict Join Date: Mar 2011 Location: easton
| c0bra's wroncho
ive had this thing for a while and got an idea a few weeks ago after i got a wraith, and after seeing all of the wroncho threads. so i decided to do mine similar but a little different. the truck isnt together yet but i will try and get it together with what i have in a few days. so far its got honcho kit ( body is flat black painted on outside with wraith stickers, back is also flat black but painted on inside) dinky rc summit cradle summit trans ( needs shifting parts and pin for slipper) wraith axles vp titanium upper links vp titanium lower links vp titanium steering links vp diff cover vp c hubs vp knuckles vp straight axle dick cepek dc-2 2.2 wheels yeah racing drifter led light kit i ordered tires but i forget what kind they are. they are from tcs and are g8 compound. im thinking about getting a castle short course system for this because its just meant to be a fun basher and the occasional trail driving Last edited by c0bra; 01-05-2013 at 10:23 PM. |
10-03-2011, 07:20 PM | #2 |
Newbie Join Date: Oct 2011 Location: us
lets see some pics of the build ! |
10-03-2011, 07:22 PM | #3 |
RCC Addict Join Date: Nov 2007 Location: -
10-03-2011, 07:34 PM | #4 |
ok ill try and get it mostly put to getger tonight. The body still needs drilled and final assembled, still need tires but they are on there way.
10-03-2011, 09:27 PM | #5 |
Rock Crawler Join Date: Aug 2011 Location: tri cities
[QUOTE= i ordered tires but i forget what kind they are. they are from tcs and are g8[/QUOTE] ??? |
10-03-2011, 10:03 PM | #6 |
heres a pic of how it looked before all the vp parts and wheels heres a pic of body. its flat black painted on the outside with wraith and some honcho stickers got the chassis all together. forgot to list the alloy rear shock towers. all off the vp links are together but havent started on the front axle yet tho. there are blue leds in the front bumper which will flash, with red ones in the rear. i may put rock lights on it but still unsure. Last edited by c0bra; 01-05-2013 at 10:24 PM. |
10-03-2011, 10:14 PM | #7 |
Do you got pics of your links? I'm getting wraith axles and I wanna see how you did your links
10-04-2011, 03:42 AM | #8 |
Rock Stacker Join Date: Jan 2011 Location: Singapore
has anyone tried using the Wraith skid plate for the honcho transmision mount? wonder if the width n mounting holes are the same? reasons being i m having clearance issues with the front upper links.. as for the wraith the mounting holes are above the shaft, links would clear better.. anyone tried? |
10-04-2011, 07:37 AM | #9 | |
10-04-2011, 08:00 AM | #10 |
10-04-2011, 08:14 AM | #11 |
10-04-2011, 08:16 AM | #12 |
10-04-2011, 09:50 AM | #13 |
If you use the x trail frame from tcs crawlers the axles work perfect cause of where the top links bolt to. I'm gonna pick my up the chassis kit and some wraith axles
10-04-2011, 01:31 PM | #14 | |
im going to try and get the rest of the chassis together today and hopefully stary on my lcg slash conversion as well. i checked the order from tcs. i ordered proline chisels in g8 compound. i dont know how good they will be for what im doing with this but its worth a shot. Last edited by c0bra; 01-05-2013 at 10:26 PM. | |
10-04-2011, 03:07 PM | #15 |
i got the suspension in. the shocks still need to be mounted to the shock tower and it needs electronics, tires, and need to decide were to mount everything front links from top. the front and back links are set up the same way. the bend in the links is closer to the axle, but were ypu mount the lower links isnt in the same spot as the stock skid. the dinky summit cradle drops the mounting hole side view of chassis summit cradle from the dinky rc thread. just to give you an idea |
10-05-2011, 11:51 AM | #16 | |
10-05-2011, 02:41 PM | #17 |
| nice the only problem is drive shafts and the upper links. ive heard you can use maxx shafts or get a 6mm mip and a 5mm mip as well and its supposed to work
10-21-2011, 01:42 PM | #18 |
lost interest in the stock ish looking wroncho. after remembering this set up i decided to make this thing a little taller. after an hour of searching for my ax10 chassis and scx chassis with the holes in it to mount the ax i got to work. so far everything has gone smoothly and the driveshaft doesnt look like too much of an issue, however i cant use the summit cradle because it hits the ax chassis. right now all it needs is the rear shocks mounted, trans and driveshafts mounted, electronics installed and rest of leds installed as well. will post pics after i get the chassis a roller! |
10-21-2011, 02:32 PM | #19 |
ran into a problem. when i went to put the diveshafts on, they hit the lower links. so i rotatated the skid so the output shafts on the trans were on the opposite side. now the driveshafts dont hit the lower links. however now i have to limit the suspension travel because the driveshaft binds really bad |
10-21-2011, 02:51 PM | #20 |
RCC Addict Join Date: Jul 2011 Location: Orlando
