Newbie Build + Questions 3 Attachment(s) I've been stalking the boards for a while as I contemplated jumping into RC'ing and continued to do so while I worked on the build out on my Dingo kit. I was trying to keep it relatively budget friendly, without buying something I would be upgrading or replacing in a month. I believe I struck a good balance but I supose time will tell. As a recent Austin, TX transplant into the heart of Brooklyn I'm hoping this will keep scratching the car itch I left behind with my 99 heavily modded TJ, and 67 Chevy C10 Rodstoration project I left at about 50% completion in my garage back home. Components: Dingo Builder's Kit Holmes BRXL waterproof ESC Axial 27T Motor Savox SA1230SG (great price at $74 Shipped from Amazon). FlySky GT-3b Radio GenAce 4000 mAH 3s battery Off Brand 12 LED light Kit Build Notes: I wish I had paid attention to the mirror/flipping threads while building it. I took the dang thing off and turned it around thinking I had it wrong, only to find out that it is the flipped and often preferred setup! Gluing tires, is not awesome. I already am not happy with the stock foams so to pull them off was not the easiest task and no have a few rough edges. I'll likely be picking up some beadlocks this week instead of gluing the ripsaws in place again. I have been happy with them, but have run them since day one with ever other outer tread shoulder cut off. (I was waiting on my ESC to arrive for two weeks and wanted to stay busy on the build). I four linked it right away, and of course found the front end to be off so I set it up with the all thread and Revo links. Easy enough job, that seems to help a lot, as now the servo arm will clear the frame and I picked up a LOT more travel up front. Savox seems a bit noisy, but this is my first RC and first electronic servo so I have no baseline to compare it too. It works great though. Paint: I wish I had paid better attention to the crevices of the tub, and the hard edge body lines when laying down the color. It came out too thin in several spots. Off Brand Contact Cement will take off the fully cured paint (See the paint blemishes around the headlights). Next up: Installing six quick connects on the body mounted LED leads so I can quickly pop it off and on. Filling the stock drive shafts to stop the eventual collapsing. Weights in tires. Thoughts & Questions: The thing runs great except at full speed it seems to get overloaded and will just stop for a second, or at full turn and mid-high throttle again the radio seems to get overloaded. What would cause this? Again without a baseline, but this sucker is pretty quick for what it is. In terms of power/scale it has way more torque and "Hp" than a 1x1 would have :) With the setup I am running would you guys suggest changing out any parts (Motor, gearing, pinion?) I'm a big fan of the run it until you break it model, but wonder if since I picked out my own electronics if it is obvious that I have massively over specced anything? Yesterday was the first chance to really play with it, the weight is pretty well distributed but I need more up front to keep the nose glued down on steep climbs (wheel weights). It was a ton of fun, and a surprisingly good performer. |
Re: Newbie Build + Questions You need to run a bec. That will solve your overload problem."thumbsup" http://www.rccrawler.com/forum/elect...ernal-bec.html |
Re: Newbie Build + Questions I would have went a bit more conservative on your electronics and put some money saved towards a set of bead-lock rims...glue issue - SOLVED! Trying to add wheel weights to a glued tire...NOT HAPPENIN'! But that is self-critiquing. The Savox servo is an energy monster! So, if you're running anything built by castle as an ESC (I dont know who manufactures your ESC), its going to glitch out from a lack of power. An external BEC will bypass the power output from the ESC and feed power straight from the battery to the servo - should fix that issue. When you consider the cost of a BEC and Savox servo, may consider swapping out for a different servo not requiring a BEC. All good learning point! Truck looks nice, but I'm going to warn you now...Its not going to look like the pictures in another month. From the looks of things, you have the fever and you're going to upgrade and mod EVERYTHING! hehe Welcome to the Addiction! |
Re: Newbie Build + Questions Looks good so far. I would have to agree with redsawacs. It wont be long until you change everything and it does not look like that anymore. |
Re: Newbie Build + Questions Quote:
Re: Newbie Build + Questions Every crawler needs an external. Just the nature of the beast."thumbsup" |
Also, cheap G-Made beadlocks are in the cart with the Novak Cap. "thumbsup" |
I already trimmed and capped the stock bumper as it was keeping me from getting to many of the obstacles I wanted to try and climb. Started with it trimmed up to the outer bars, but suspect I'll be whacking it off shorter to give full access to the front tires. White wheels, and a better grill/headlight combo are on the list too. |
Go Celtic Football!:mrgreen: |
