Thread: A couple of Vanquish Products questions
Old 01-24-2014, 10:02 PM   #1
Default A couple of Vanquish Products questions
Working on a new SCX10 project using Currie axles, panhard kit, and front bumper mount/CMS. Also using 1.9" KMC Enduro wheels.
First question, Will the VP 8 degree Knuckle Weights fit with the 1.9 Enduro wheels? The description states it fits all 2.2 wheels, but I want to be sure they also fit these wheels before I order a set.
Second question, Using the VPCurrie axle with the VP CMS/bumper mount, I seem to be having some clearance issues with the servo arm. Is anyone else using this setup and how did you configure it? pics would be awesome.
note: the draglink is only installed that way as a test fit
Cultus is offline   Reply With Quote
Old 01-24-2014, 10:17 PM   #2
Default Re: A couple of Vanquish Products questions
is your servo arm hitting. You may need to get a shorter one. Yours looks a bit longer.
MaxxPain is offline   Reply With Quote
Old 01-25-2014, 01:58 AM   #3
Servo arm needs to face forward,not backwards..
ROLANDROCKSHOP is offline   Reply With Quote
Old 01-25-2014, 08:55 AM   #4
Looks like the servo arm is on right. This pic is from Phams build.
http://i1200.photobucket.com/albums/...ps2041969a.jpg
Old 01-25-2014, 10:35 AM   #5
thought about that, its certainly one option
that looks like the servo is mounted above the CMS? considered doing that too. so this setup doesn't hit anywhere?
Old 01-25-2014, 07:21 PM   #6
It looks like if you move the servo from under the mount to on top of the mount you'll have more room.
EDIT: It looks like you thought of that too....lol
T I N Y is offline   Reply With Quote
Old 01-25-2014, 10:18 PM   #7
move the servo to the top of the mount..
allanon1965 is offline   Reply With Quote
Old 06-14-2014, 06:57 AM   #8
Glad i searched. I have the same problem, thought about doing that but wasn't sure if i'll be doing it right. Love this forum!
<<<< Tapatalk HD>>>>
dextan22 is offline   Reply With Quote
A couple of Vanquish Products questions - Similar Threads
vanquish products ridgecrest78 Axial AX10 2nd-gen 14 08-18-2012 02:40 AM
