10-12-2014, 08:58 AM | #1 |
Pebble Pounder Join Date: Jan 2013 Location: Australia
| scx10 dingo won't climb help!
Scx10 dingo stock wheel base it struggles to climb on a lot of steep hills loose dirt or even Rocky inclines, it has tekin hd 35t 87t/17t on 3s alloy links battery behind front shocks tsl sx tires on rc4wd 6 lugs 1.9s stock 90mm shocks with 30wt rrp gears in trans ae2 esc with bec 10amp cys 2200 servo, Any Tips Would Be Great !! |
10-12-2014, 09:01 AM | #2 |
| Re: scx10 dingo won't climb help!
We need more info. Compared to what? How does it struggle? Does it just spin the tires? Does it flip backwards? Ect... |
10-12-2014, 09:19 AM | #3 |
It spins and digs holes flips backwards just spins more
10-12-2014, 09:21 AM | #4 |
Quarry Creeper Join Date: May 2014 Location: Burlington, ON Canada
So traction and weight distribution sound like the problem. - Better tires - Forward weight bias - Weighted axles - Lower gearing maybe...if you don't mind compromising speed |
10-12-2014, 09:26 AM | #5 |
I found that if I push down on the body well it trys to climb a steep hill it will climb it so what tires are better and how can distribution the weight better ?
10-12-2014, 09:35 AM | #6 |
Newbie Join Date: Sep 2014 Location: Alabama
Mount the battery more forward than it is and/or add an ounce or 2 of weight to the servo
10-12-2014, 10:28 AM | #7 |
Quarry Creeper Join Date: Jan 2012 Location: winder, ga
I have found that driving style plays a big roll on steep hill climbs. Try practicing steady throttle control, keeping the tires moving without breaking traction. Slower may be better in some situations.
10-12-2014, 10:57 AM | #8 |
I wanna be Dave Join Date: Jan 2009 Location: New Port Richey, FL.
A vid would be great to see first before making suggestions.
10-12-2014, 11:47 AM | #9 |
Rock Crawler Join Date: Mar 2012 Location: UK, Hampshire
If you still have have stock foams in the tsl's you have probably noticed they are very soft, i put some 2.2 sized memory foams in mine and improved handling greatly, weighting the front wheels will help. My dingo wheel based scx10 climbs as well as when it had a honcho wheel base Here's my build thread: http://www.rccrawler.com/forum/axial...-cherokee.html |
10-12-2014, 02:37 PM | #10 |
Ok thanks guys will get a video I belive axle servo weights will help a lot
10-13-2014, 03:49 AM | #11 |
| Re: scx10 dingo won't climb help! |
10-13-2014, 04:12 AM | #12 |
Pebble Pounder Join Date: Aug 2014 Location: uk
Big tumble!!did you break anything?a picture of the layout of your truck might help people,a shot from above with no shell.
10-13-2014, 04:16 AM | #13 |
nothing broke how do you put pics on here ?
10-13-2014, 04:19 AM | #14 |
Good to know. I use tapatalk on my phone so it will be different if using a PC. |
10-13-2014, 04:23 AM | #15 |
do u have facebook?
10-13-2014, 04:31 AM | #16 |
No sorry. What are you using? |
10-13-2014, 04:44 AM | #17 |
ok. as in ? |
10-13-2014, 04:57 AM | #18 |
Pc, laptop, tablet, smartphone, apple etc?
10-13-2014, 05:10 AM | #19 |
pc, smartphone
10-13-2014, 05:21 AM | #20 |
If your using tapatalk on your phone you expand the quick reply box by pressing the + button then press the camera, you can add from gallery or directly from the camera. Applies on my galaxy s4 not sure about others. On a pc it will be the same sort of process I should imagine, just need to find the add attachment or similar button when writing a reply.
Tags |
scx10 dingo steep help |
scx10 dingo won't climb help! - Similar Threads | ||||
SCX10 Dingo, Jeep Rubicon, Jeep Wrangler G6 hill climb rock bouncing | TAFF1969 | Scale Videos! | 0 | 07-16-2014 10:53 AM |
RC Hilux defender 90 dingo honcho Jeep Brute bug up slope climb offroad adventures | boolean21 | Scale Videos! | 0 | 07-18-2013 09:03 AM |
Axial SCX10 - The Climb Part 2 | Holdencars | Scale Videos! | 0 | 05-08-2013 01:08 AM |
Dingo Hill Climb | Spidernad | Scale Videos! | 0 | 05-18-2012 01:35 PM |
Scx10 Honcho Hill climb | country_crawler | Scale Videos! | 7 | 01-11-2011 01:25 PM |
