Thread: Thinking about doing a leaf spring build.
Old 09-20-2014, 07:11 AM   #1
Default Thinking about doing a leaf spring build.
I'm thinking about doing a leaf spring build. I know RC4wd has spring kits... Who else has them? And how do you guys like them.
HYPEracing is offline   Reply With Quote
Old 09-20-2014, 10:00 AM   #2
Default Re: Thinking about doing a leaf spring build.
Not sure who else makes them for the scx10 but my buddy did leafs on his old scaler and it absolutely killed the performance. Not sure if it was just the kit he used (can't remember which one) or if it was how he mounted them. But it definitely was worse on the trails.
Anti Hero is offline   Reply With Quote
Old 09-20-2014, 01:57 PM   #3
I have an SCX10 that is my trail runner. I just want a very realistic scaler. I would like it to have decent performance if possible, but I'd go for looks over function on this one.
Old 09-20-2014, 02:34 PM   #4
the scx-10 chassis frame rails are not inline
with the axle's preferred leaf spring mounting holes.
so the rc4wd kit has to mount to the outer side of the
scx-10's frame rails.
works... but not really the look I'd be after.
Instead...
I'd keep the scx-10 for trail runs and general operations...
then purchase a rc4wd TF2 chassis as my leaf sprung, scale rig.
^ Don't worry... you'll get to spend some of yer money,
when ya mod the TF2 chassis/susp. exactly to your liking. Lol
IMO... the TF2 makes for a great start
when considering a leaf sprung rig.
good luck to ya, going either way
TacoCrawler is offline   Reply With Quote
Old 09-20-2014, 03:10 PM   #5
the sawback is an excellent option too. decent crawling performance for a trail tuck, id say its almost equal with my scx'es. it needs a few tweaks out of the box but id say im happier with it than my tf2, although, the 2 speed in the tf is cool
stevem50 is offline   Reply With Quote
Old 09-20-2014, 04:16 PM   #6
^ oh yeah... forgot about that chassis.
I like that chassis as well.
maybe I forgot...
because I'm not a huge fan for jeep bodied rigs
Old 09-21-2014, 12:42 PM   #7
I bought GCM 4Ten chassis kit that uses Tamiya or RC4WD leaf springs and SCX10 axles, but changed them out to RC4WD first generation Toyota axles with leaf springs for more of a scale look and really love my leafed spring-ed r/c.
kgb424 is offline   Reply With Quote
Old 09-22-2014, 05:16 AM   #8
I'll have to look into these other chassis. I have a spare scx-10 frame lying around. So the plan was to build that up. I also have spare axles, and lots of small parts for the scx. I'm going to have to look at the other ones.
Old 09-22-2014, 06:39 AM   #9
With an scx10 chassis you just need to take the taper out of the rear or front of the frame and screw the leafs into the upper holes on the axial axles.
With this the leafs mount outside the chassis rails and seems to be fine so far.
I'm still building vs driving....
doublej is offline   Reply With Quote
Old 09-22-2014, 08:26 PM   #10
Too many options. Even the new vaterra K5 blazer looks like a contender.
Old 09-22-2014, 08:54 PM   #11
the leafs will probably kill your performance but if your looking for scaliness thats not really a problem. i think i saw an scx10 with a tf2 leaf spring set up, but i don't really remember much about it.
Hammer! is offline   Reply With Quote
Old 09-22-2014, 09:10 PM   #12
I own two SXC10's that I four linked and put the servo's back on the axles, and wanted a R/C with leaf springs, but wasn't going to pay $400 plus for a TF2, I found my kit on E-bay. I got my GCM 4Ten chassis for less than half price, it went from Canada to a guy in Italy then to me in the U.S.A. It been half around the world before I started building it.
Old 09-22-2014, 10:27 PM   #13
yeah i was thinking about a leaf sprung yj for my next build but i couldn't decide on what chassis.
Old 09-23-2014, 08:47 AM   #14
I am too looking at setting up a rear leaf setup. Feel like if setup right it could add a lot of performance on the trail, helps keep the rig from unloading so much. Picked up the rc4wd kit along with there red (soft) springs from someone at a comp. After looking at them I was worried about smashing them and bending them (already planned on a traction bar) so I kinda threw it on the back burner. Then I saw someone on face book with a rear leaf sprung SCX10. It looked great. Messaged him and he recommended the Delrin leafs, you can fold them over and they will spring back. Here is a pic I stole from him. Maybe he is on here???
802coma is offline   Reply With Quote
Old 09-23-2014, 06:09 PM   #15
I did rear leafs in my scratch build bronco. I did have a problem with them bending some on a bounce then the truck wouldn't sit level. Very irritating to me. My fix was running rc4wd scale shocks next to the leafs with internal springs. Now they just look like dampeners when in fact they hold most of the weight. That helped out big time and still looks pretty scale.
Jcplante is offline   Reply With Quote
Old 09-29-2014, 11:42 AM   #16
I am using the RC4wd leafs for now on my not finished CJ-7 rig i'm building... I was also thinking of switching to delrin leafs but will see how it handles first then move on from there.
Here a shot of mine:
I'll follow this post to see how your build moves on
Oldskoolcj is offline   Reply With Quote
Thinking about doing a leaf spring build. - Similar Threads
RcBros Leaf Spring Honcho Build RcBro Axial SCX-10 192 02-18-2013 02:38 PM
Scale FJ40, leaf spring tlt build. 76kcfdeng 2.2 Scale Rigs 55 10-10-2006 01:34 PM
Second leaf spring build ddiaz10240 2.2 Scale Rigs 8 06-23-2006 12:44 AM
scale leaf spring tlt build '83 chevy Tamiya TLT Crawlers 7 03-08-2006 05:45 PM
