Thread: More Scale Driveshafts?
Old 04-13-2015, 08:43 PM   #1
Default More Scale Driveshafts?
I am looking for something that's a bit more scale than a CVD style shaft or stockers, not that I can't use stock shafts....these have appeared during my searches:
http://www.amazon.com/Crawler-Drive-...GH9FRHHJTNQSHE
After reading the last 4 years of posts regarding driveshafts I can't find much that don't recommend Junfac or MIPs. I just want something that looks more real with universals and such....thought of building some out of Traxxas parts but figured I would ask here first. Thanks in advance,
Jay
(redbeard) is offline   Reply With Quote
Old 04-13-2015, 08:52 PM   #2
MODERATOR™
EeePee's Avatar
Default Re: More Scale Driveshafts?
Manufacturer recommended age: 8 - 15 years
EeePee is offline   Reply With Quote
Old 04-13-2015, 08:59 PM   #3
The other option I've found is these:
RC4WD Punisher Shaft II (90-120mm, 3.54"-4.72") 5mm F-350 Hi-Lift
Old 04-13-2015, 09:12 PM   #4
Traxxas driveshafts work well and are inexpensive. You just have to drill the outdrives out to 5mm; the diameter is already there, but there are flat spots that need to be removed. They are also much easier to shorten than steel shafts.
For durability, I have used both T-Maxx 2.5 shafts/outdrives as well as Slash shafts/outdrives on my 10lb 6x6 without issue.
Slash shafts would be more scale than Maxx shafts...
micro racer is offline   Reply With Quote
Old 04-13-2015, 10:32 PM   #5
STEEL BOAR UNI JOINT
corkysk8 is offline   Reply With Quote
More Scale Driveshafts? - Similar Threads
Ultra Scale Driveshafts jcsaxial General Scale Talk 3 08-28-2013 11:04 AM
RC4WD new scale driveshafts STANG KILLA SS General Scale Talk 17 12-30-2012 03:35 PM
1/10 scale brushless (driveshafts) goslo Axial AX-10 Scorpion 5 09-02-2008 08:43 PM
