HELP!!! just realized I order the wrong C hubs and steering knuckles After placing the order on amazon prime, I decide to read the description which states the parts I orderd will work with the Axial ax10 rock racer... I thought I was ordering for my Honcho but I was wrong.... my question is will these work on my Honcho axles? My order already processed so I have to wait till they arrive and send um right back if they do't work... thanks in advance part numbers in question : AX130495 :front C hubs AX30496 steering knuckles |
Re: HELP!!! just realized I order the wrong C hubs and steering knuckles I believe the AX uses the Wraith axles.If that's the case then no they will not fit. |
Re: HELP!!! just realized I order the wrong C hubs and steering knuckles The parts you have ordered will work fine on your SCX10. If you search the part numbers it will find the Axial pages for them Axial Racing - Aluminum C Hub Carrier - Black (2pcs) Axial Racing - Aluminum Knuckle - Black (2pcs) Way back when Axial sold an AX10 crawler, they then re-used those axles on the SCX10 scaler. Sometime later having dropped the AX10 from their line they bought out a new one which uses the axles found in the Wraith. If you by AX10 "Scorpion" parts they'll mainly fit your SCX10. If you buy AX10 "Deadbolt / Ridgecrest" parts they likely won't. |
Re: HELP!!! just realized I order the wrong C hubs and steering knuckles You are ok. Those are correct... just really really old! The original AX10 rock racer predates the SCX10 but uses the exact same axles... the new AX10 uses AR60 (Wraith/Bomber axles, no idea why Axial recycled the name but it's caused problems for customers. I will say, it's kind of a bummer that you got those old knuckles because they make a high steer version that works better by giving you a little bit more steering and raise the link out of the way some. EDIT: lol, yeah... what he said! (guess I'm a slow poster) |
