Thread: lower front bumper mount option ZR2 build
Old 03-30-2019, 07:29 PM   #1
Default lower front bumper mount option ZR2 build
I have the Pro-Line Colorado ZR2 body trimmed,mounted and positioned in a pretty good position on My New SCX-10II (Wrangler) chassis. I have the back Jeep bumper on and aligned with my rear Pro-Line rear bumper body line and it looks good.
The front bumper will need either a lower mounting point or I'll have to trim off a lot of the Colorado body to have a functional and protective bumper.
My question is what parts and mounting options are available where I can drop the attach points and still use the stock Wrangler (CRC) bumper.
Basically come off the frame rails, drop about 1/2" and than have the bumper line-up just below the bodyline without having to trim so much off.
Jettcity1 is offline   Reply With Quote
Old 04-01-2019, 12:25 PM   #2
Default Re: lower front bumper mount option ZR2 build
Did you trim off the lexan bumpers?
Xx Losungen xX is offline   Reply With Quote
lower front bumper mount option ZR2 build - Similar Threads
reverse front shackle while using stock front bumper mount? iluvny081 RC4WD Trail Finder 2 1 10-24-2017 12:32 PM
Jk front bumper mount? scx-chevy Axial SCX-10 7 08-13-2013 06:49 PM
WK lower link mount option ... other possibility ? truespace HPI Wheely King 10 06-28-2009 07:47 PM
