06-06-2016, 04:46 PM | #1 |
Metal shaper Join Date: Dec 2008 Location: Hog Eye, Texas
| CFM builds MadMaXJ 2.0 Well I didn't intend on getting one of these as it didn't peak my interest to the level of some things but wanted a set of the axles to modify and make better so I said why not. Decided it would be a "clone" of my 1:1 XJ that I've done before with the proline body and currently doing a highly detailed super scale version with the import XJ hardbody. First was inspection of all the new stuff and putting the mics to things and seeing what's what and what's possible. Overall initial impression is that Axial really listened and has been paying attention. The layout of the chassis and new axle design is a huge step forward. It's the only chassis offered with a built in servo winch mount. I'll get into my thoughts and things I've done different to suit my needs with this new rig and hope y'all enjoy. |
06-06-2016, 04:53 PM | #2 |
| Re: CFM builds MadMaXJ 2.0 First thing I went to were the tires to measure, feel, and compare. They measure out to 4.550", new foams are better than previous versions, the width is a bit much as I prefer the Prolines profile better. The Axial version also is lacking on some of the sidewall detail that is included on the Proline tire. Compound is said to be R35 but is reminiscent of the 2.2 "R35" trepadors that are different in color, feel, and these lack the white dot that is familiar. They feel more along lines of the new S30 compound which isn't horrible. Overall, another great option in the middle of the road sizing for Class2 rigs that don't want an aggressive tire. Next were the wheels. Those that know, may remember we used to produce the licensed Method Mesh Delrin 2.2 wheels so I was pleased to see a smaller version being offered finally. Typical glue on wheel with the exception of a heavy duty hex area which is much appreciated, especially if you decide to SLW mod the wheels. |
06-06-2016, 05:02 PM | #3 |
| Re: CFM builds MadMaXJ 2.0 Next I went straight to the axles as that was the whole reason for this rig for me personally. The smaller diff is awesome, detail on it and the cover are nice, gear quality looks great and the universals have crazy functional angle. [IMG]http://uploads.tapatalk-cdn.com/20160606/646a441a223c6347acc9529cf9da3062.jpg[/IMG Next thing I wanted to do was make comparisons of existing axle shafts. A Scx vvd is close but no cigar. The centerline pivot is off which would create binding. Grabbed a Scx narrow mod XR shaft and the joint centerline is good but inner bearing surface is way off. Then I got to wondering how the new parts match up to the old housings. Pow!!!!! Now the disclaimer. These housings have brass inner tubes which are a must if you do this mod. You have to grind the little nubs off for the original chub mounts on the housings. After I set the angle of the new chubs I drilled a hole to match up with the original chub screw hole to add peace of mind. You'll need a new tie rod, and either a 4 link truss or aftermarket 3 link truss for your upper suspension link. Other than that, everything bolts up and works fine together and has killer turning. These are the axles going in my 2.0 as I have different plans for the ar44 housings.....much more on that later. |
06-06-2016, 05:09 PM | #4 |
| CFM builds MadMaXJ 2.0 Next was the body, which was the reason I really didn't want to building of these as it's just not to my liking. Yes it has great 3D scale additions that make it look great. But....it has huge fender flairs modeled after the 1:1 leaving you with zero options there. A bolt on flair would have been awesome for hose not wanting a huge fenderwell opening. I started comparing the body to the other XJ options and parts compatibility. The hardbody fits down inside this one, it's huge!! Bumpers are also a touch wide for the hardbody and much too wide for the proline body. Roof rack will work but extremely close call on the hardbody. It was too big for the proline body. I think with some careful trimming you might be able to get the grille in the proline body but in not gonna be that experiment. The body posts are all new design do you won't be able to cross reference those but they are much stronger and supply several handy options. Still curious where the .040" claim is found at. Maybe it started life as a thick sheet but it's not there anymore unfortunately. Last edited by CarterFab; 06-06-2016 at 05:16 PM. |
06-06-2016, 05:14 PM | #5 |
Wasn't gonna even build it but my family was spread out out of town this weekend so I spent a couple late evenings putting it together. The chassis is same as old with exception to a few extra holes for the new style trans mount. It uses the same skid mourning dimensions and includes two versions. One win old style trans case mount pattern. That's great as I didn't initially want to run the giant trans with the motor so far back. That said, when I started building, I was able to mount the motor forward for more scale, better weight bias, and personal satisfaction. Still kept the CMS option and forward battery mount that worked out to be the identical size of my 1300 and 1400mah 3s packs. The organization integrated into the chassis seems to be something with the new rigs coming from Axial and it's a great addition. Everything is tidy. Also the new sliders are a big improvement and the adjustability for width is great if you change bodies. |
06-06-2016, 05:24 PM | #6 |
Now to the things I didn't use and changing for this rig personally other than what's been mentioned. Not running the Icon shocks as there hasn't been any changes there. I'll be running the short traxxas big bores. Mounted my Locked Up RC Commando winch up front. Bolted right on without mod. Drilled the bumper to bolt a real fairlead on. Trimmed the fender flairs off the rear but left the fronts despite really disliking the look. Had a Proline interior handy and it's a little undersized, mostly on length, but it will work for this project and looks nice. I'll be swapping to a Dinky RC universal 3D interior later when I make some changes to match how the 1:1 is built now. Mounted up a set of Duratrax Scaler tires as they are close to the old school MTR. Mounted them on a set of Duratrax scale wheels that are SLW modified. I'll be swapping the wheels out for exact matches from Locked Up since they produce the scale version of our Beadlock rings. Shown with tall bigbores so it will sit quite a bit lower once I get the shocks swapped out. |
06-06-2016, 08:24 PM | #7 |
RCC Addict Join Date: Jan 2007 Location: Arkansas
Nice! Someone finally turns that transmission around! Any idea if a 2200 pack will fit in the battery tray now?
06-06-2016, 08:26 PM | #8 |
RCC Addict Join Date: May 2007 Location: pasadena, tx
where did you get your pivot balls? ive been looking for a place where i could buy a whole bunch.
06-06-2016, 08:31 PM | #9 |
| Re: CFM builds MadMaXJ 2.0 |
06-06-2016, 08:32 PM | #10 |
06-06-2016, 08:39 PM | #11 |
06-06-2016, 08:40 PM | #12 |
Traxxas sells packs of anodized aluminum balls with out rod ends
06-06-2016, 09:10 PM | #13 |
06-06-2016, 09:19 PM | #14 |
Rock Crawler Join Date: Jul 2011 Location: palm desert (southern cali)
They sell normal ball ends http://www3.towerhobbies.com/cgi-bin...FYeUfgodaYAJkQ Sent from my iPhone using Tapatalk |
06-06-2016, 09:59 PM | #15 |
06-06-2016, 11:26 PM | #16 | |
I wanna be Dave Join Date: Apr 2015 Location: Roseville, Ca
| Re: CFM builds MadMaXJ 2.0 Quote:
Length: 5mm (0.20") Outer Diameter: 4.5mm (0.18") Inner Diameter: 2.5mm (0.1") Revo balls is 7mm length, outer 5.76mm, inner 3mm. Those won't work. | |
06-06-2016, 11:29 PM | #17 |
Well shit touché my friend lol Sent from my iPhone using Tapatalk |
06-07-2016, 04:05 PM | #18 |
06-07-2016, 05:10 PM | #19 |
Newbie Join Date: Jun 2016 Location: Rockville
With flipping the trans and center skid like that, how did it affect your link lengths? I'm hoping to do something similar with mine (once it comes...) and am thinking of running the ESC up front in the battery tray and mounting the battery sideways across the frame rails behind the trans to get it nice and low (yes, i still run a big 5000 mAh 2s).
06-07-2016, 05:49 PM | #20 | |
Quarry Creeper Join Date: Jun 2009 Location: ...
CFM builds MadMaXJ 2.0 - Similar Threads | ||||
Rock Spyder by CFM | CarterFab | 1.9 Scale Rigs | 90 | 04-17-2014 12:35 PM |
Venom One by CFM | CarterFab | Axial Wraith | 73 | 07-22-2013 10:16 AM |
looking for prerunner builds. post builds here | wcdfmt510 | General Scale Talk | 19 | 06-27-2013 09:48 PM |
