05-09-2017, 07:57 AM | #1 |
Quarry Creeper Join Date: Mar 2016
| Traxxas shocks
What are the part #s for Traxxas big shocks and the part# for the gold springs. Looks like I have some EBay money I didn't know I had . Sent from my iPad using Tapatalk |
05-10-2017, 11:59 PM | #2 |
| Re: Traxxas shocks
If you're talking about Traxxas big bores, the part numbers are 2662 for the 100mm length and 2661 for the 95mm length which is closest to stock length shocks. I don't know which gold springs you are referring to but any Axial 14x70mm springs fit like a glove. Orange front and purple rear is a good place to start. Red front and orange rear if you have a heavy rig.
05-11-2017, 05:25 AM | #3 |
Quarry Creeper Join Date: Mar 2016 Location: Midlands
| Re: Traxxas shocks
Traxxas 2661 (93mm) big bores can be run with the stock scx10ii springs. It's a close fit, but they do fit. I'm running 2661's on the front with the stock springs and 2660 (84mm) in the rear with some HPI 14*60*1.1 springs to suit my pick-up & shorter hoops. |
05-11-2017, 10:51 AM | #4 |
| Re: Traxxas shocks
You will be happy Hang up and Drive |
05-14-2017, 01:24 PM | #5 |
| Re: Traxxas shocks
I'm happier with traxxas tried and proven, hard anodising and ti coated shafts....and more subtle aesthetics... but beauty is in the eye of the beholder and all.
05-15-2017, 12:09 AM | #6 |
Pebble Pounder Join Date: Aug 2016 Location: N/A
| Re: Traxxas shocks
Another vote for the Big Bores. I'm so glad I found out about these from Screamer.
05-15-2017, 08:58 AM | #7 |
| Re: Traxxas shocks
I got mine installed wow they work nice. I think the Losi gold springs are a little stiff for the rear. I found a set of 1.04 spring rate going to give them a try. The ring is so much more stable and the flex is incredible. Great upgrade. Sent from my iPhone using Tapatalk |
05-16-2017, 08:25 AM | #8 |
Pebble Pounder Join Date: Sep 2012 Location: Rockford
| Re: Traxxas shocks
Traxxas big bores with losi mini springs or associated rc18t springs are a great combo for many trucks. I run the Rc Surface department at Hobby Town in Rockford. I've been into scale type crAwling for 8 years. I actually build and sell Traxxas big bores built with gold rc18 springs. We sell a ton of them. Locally there called Todd Shocks. These are what they look like with Beef Tips by Beef Tubes Sent from my iPhone using Tapatalk |
05-16-2017, 08:36 AM | #9 | |
| Re: Traxxas shocks Quote:
05-16-2017, 08:42 AM | #10 |
| Traxxas shocks
Many MOA crawlers do that they work well, don't stick out , and can be run upside down for weight Hang up and Drive |
05-16-2017, 09:22 AM | #11 |
| Re: Traxxas shocks
They look neat and make for a lot slimmer shock. I've also setup guys with axial 14x70 springs and they work great. Beef tubes makes a few style of spring retainers that all work great and add some weight. Plus they will never fall off. Sent from my iPhone using Tapatalk |
05-16-2017, 11:08 AM | #12 |
| Re: Traxxas shocks |
05-16-2017, 11:29 AM | #13 |
05-16-2017, 11:31 AM | #14 |
| Re: Traxxas shocks
Other benefit is no rubbing on the body of the shock Hang up and Drive |
05-23-2017, 09:02 AM | #15 | |
Rock Crawler Join Date: Apr 2015 Location: Paola, ks
Sent from my SM-N920V using Tapatalk | |
05-23-2017, 09:25 AM | #16 | |
No those are from Dlux, fit perfect and priced right. https://dluxfab.ecwid.com/#!/No-pre-...tegory=6232188 Hang up and Drive | |
Traxxas shocks - Similar Threads | ||||
Losi .6 shocks versus Traxxas GTR/E-revo shocks. | 5150bronco | Axial AX-10 Scorpion | 34 | 01-07-2009 12:37 AM |
