K5 build up This will be a slower paced build up of what im doing with my 10.2 rtr. I will update the build as I go. Rock beast xl Boom Racing KRAIT[emoji769] Beadlocks 2 stage foams comp inners & soft-front/med-rear Holmes torquemaster 35t 9tpinion SSD HD diff covers In the process of adding: Crawler space comp spec chassis plates Vader high clearance skid Ncision link kit Bilstein 90mm sz series RC4wd K5 body Will update pics as I go. And more to come!https://uploads.tapatalk-cdn.com/201...2167e1072e.jpghttps://uploads.tapatalk-cdn.com/201...38b23f68e0.jpghttps://uploads.tapatalk-cdn.com/201...a0ed08c768.jpg Sent from my SM-G955U using Tapatalk |
Re: K5 build up All torn down. You can see the clearance difference of the skid plate. There are a few minor issues I've ran into so far: 1. I need a hardware kit bad, I'm running thin on my assortment. 2. I ether need to figure out a different top 4 link mount on the chassis, or get angled links. Hopefully this weekend I can get on assembling this body!https://uploads.tapatalk-cdn.com/201...66c10355c0.jpghttps://uploads.tapatalk-cdn.com/201...eaf9cd80c6.jpghttps://uploads.tapatalk-cdn.com/201...d6e9b59d44.jpghttps://uploads.tapatalk-cdn.com/201...282064cd3e.jpghttps://uploads.tapatalk-cdn.com/201...5d6b2fe37c.jpghttps://uploads.tapatalk-cdn.com/201...a1c145abe0.jpg Sent from my SM-G955U using Tapatalk |
Re: K5 build up Starting the body!https://uploads.tapatalk-cdn.com/201...48531849ab.jpg Sent from my SM-G955U using Tapatalk |
Re: K5 build up Most of the body is finished, this thing is pretty awesome. I am blown away by the detail. Little things I need to finish. I got some more aluminum goodies, mostly chassis support pieces. Got some link mount extenders to fix my rear link binding issue. Waiting on a master hardware kit, phat axles, electronic mounts, and some king 100mm, should have this stuff Monday/Tuesday. I'm not to sure yet on how I'm going to mount this body, but I do know unfortunately I have to cut the interior, I'm going to remove it for now until I get a good chassis fitment. Might be trimming the fenders, not to sure on that yet[emoji40]. This weekend I'm going to try to get some supplies for inner fenders. I am getting the itch to get back into brass fabrication, so i might make some bumpers, sliders, and fender bars. I would love to make a cage, but time is the issue right now. Not to much going to happen for the next few days, as i am running a booth at our AAA travel show in Denver. I will update once the parts come in!https://uploads.tapatalk-cdn.com/201...753b2eaeb7.jpghttps://uploads.tapatalk-cdn.com/201...267996b35a.jpghttps://uploads.tapatalk-cdn.com/201...481102192f.jpghttps://uploads.tapatalk-cdn.com/201...925c0f1f4e.jpghttps://uploads.tapatalk-cdn.com/201...306e9491a3.jpghttps://uploads.tapatalk-cdn.com/201...621e460337.jpghttps://uploads.tapatalk-cdn.com/201...ecc4bcb63c.jpghttps://uploads.tapatalk-cdn.com/201...30893ab8d3.jpghttps://uploads.tapatalk-cdn.com/201...3a1492e0ce.jpg Sent from my SM-G955U using Tapatalk |
Re: K5 build up Got some goodies in today. 700piece hardware set Phat axles x2 Aluminium link mounts Aluminium c hubs Brass knuckles Crawler store electronic mounts Will have pics up soon Sent from my SM-G955U using Tapatalk |
Re: K5 build up Rear end is done. 4link mount to driveshaft clearance is close, but it clears. I need to build a gear cover, finish the front. I have 100mm kings coming. I have to trim some parts of the body to clear the frame. Over all it's coming together pretty decent. A teaser pic of the final stance!https://uploads.tapatalk-cdn.com/201...6ed60b7059.jpghttps://uploads.tapatalk-cdn.com/201...389eeabc89.jpghttps://uploads.tapatalk-cdn.com/201...6412ba2182.jpghttps://uploads.tapatalk-cdn.com/201...b26f011660.jpghttps://uploads.tapatalk-cdn.com/201...9132c86306.jpghttps://uploads.tapatalk-cdn.com/201...92a9d3b355.jpghttps://uploads.tapatalk-cdn.com/201...0230949e03.jpghttps://uploads.tapatalk-cdn.com/201...6f150e9db6.jpghttps://uploads.tapatalk-cdn.com/201...c1a63771e6.jpghttps://uploads.tapatalk-cdn.com/201...494f2c9e5e.jpghttps://uploads.tapatalk-cdn.com/201...0d506c9a24.jpg Sent from my SM-G955U using Tapatalk |
Re: K5 build up Few update pics I may revert back to the factory frame with this build.https://uploads.tapatalk-cdn.com/201...bd0d875779.jpghttps://uploads.tapatalk-cdn.com/201...2ec7b583a9.jpghttps://uploads.tapatalk-cdn.com/201...f866dc6fe2.jpg Sent from my SM-G955U using Tapatalk |
Re: K5 build up Gotta finish the body and mount it. Get some bumpers that will match a good fender trimming and adjust the suspension. It's getting close. https://uploads.tapatalk-cdn.com/201...64f9f550b1.jpghttps://uploads.tapatalk-cdn.com/201...0050b760bc.jpghttps://uploads.tapatalk-cdn.com/201...81c1b00eb7.jpghttps://uploads.tapatalk-cdn.com/201...dea9d6a6f8.jpghttps://uploads.tapatalk-cdn.com/201...24a726c613.jpghttps://uploads.tapatalk-cdn.com/201...91f0207bb3.jpghttps://uploads.tapatalk-cdn.com/201...b5a2c4a0a8.jpg Sent from my SM-G955U using Tapatalk |
Re: K5 build up Converted a few items, and bought some stuff. Going Class 1 With it for the start. Will update tonight Sent from my SM-G955U using Tapatalk |
Re: K5 build up Pics of the new rims, tires, and sliders. Next plan is mount the body, adjust suspension, build the inner fenders and filler panels, interior, electronics, and a possible trim on the fendershttps://uploads.tapatalk-cdn.com/201...d66cb968f6.jpghttps://uploads.tapatalk-cdn.com/201...4017a8b68c.jpghttps://uploads.tapatalk-cdn.com/201...18b8dc57a1.jpghttps://uploads.tapatalk-cdn.com/201...e4a626e6e7.jpg Sent from my SM-G955U using Tapatalk |
Re: K5 build up Got the body mounted, and working on inner fenders. There .030mm styrene. Used my Mac heat gun on low, and some 1/4 thick foam strips on my fingers to help form the plastic around the chassis.https://uploads.tapatalk-cdn.com/201...b38a635345.jpghttps://uploads.tapatalk-cdn.com/201...b96e8ed685.jpghttps://uploads.tapatalk-cdn.com/201...894108a3fb.jpghttps://uploads.tapatalk-cdn.com/201...ebf5af582e.jpg Sent from my SM-G955U using Tapatalk |
Re: K5 build up Quote:
Re: K5 build up Hey what chassis and skid are those ? Maybe you mentioned before but did not find the info. Thanks a lot Sent from my iPhone using Tapatalk Pro |
Re: K5 build up Finally got around to working a little bit on the k5. Will have a link to a test run video in my backyardhttps://uploads.tapatalk-cdn.com/201...cce5a6c794.jpghttps://uploads.tapatalk-cdn.com/201...780e217e9a.jpghttps://uploads.tapatalk-cdn.com/201...05c2f98d13.jpghttps://uploads.tapatalk-cdn.com/201...c13c00e5a7.jpg Sent from my SM-G955U using Tapatalk |
Re: K5 build up https://youtu.be/0ICip8Mx_cI. Quick test vid. Still need to trim the rear inner fenders, and interior. Sent from my SM-G955U using Tapatalk |
Re: K5 build up Out testing!https://uploads.tapatalk-cdn.com/201...9e6e8a1374.jpg Sent from my SM-G955U using Tapatalk |
Re: K5 build up Nice looking truck. It looks very Ted Nugent-esque. If only you could find him as a driver. :ror: |
Re: K5 build up I'm gonna have to look for one lol. Rear bumper lasted about 10min. https://uploads.tapatalk-cdn.com/201...fa848f0401.jpg https://uploads.tapatalk-cdn.com/201...ce0acd667d.jpg |
