SCX10-III: Things to know before you build yours (Tips) EDIT 4/6/20: The instruction manual has been updated for typos. None of the views have changed but typos and part numbers have been fixed...I hope LOL...I can look at these 100 times, think i got it and then find more after. AXI03007 Updated Manual 4/6/20 I'm sure someone will let me know :-) Hi all, I thought i would share some built tips and notes for your SCX10-III build. Hopefully you will find these handy and I would appreciate you guys sharing these as much as possible. Thanks, Rich Step A-3: Do not over tighten the portal cap screws. Its very easy using a power driver to overtighten these and crack the covers. Also note, the covers are numbered "1" and "2". They are different and specific to the axles. "1" are for the front axle, "2" are for the rear. https://live.staticflickr.com/65535/...d8f1ce5c_z.jpg Step B-1: Add a drop of oil to the o-rings before you install the cap. This helps to keep the threads from tearing the o-rings. https://live.staticflickr.com/65535/...92722e1a_n.jpg Step B-1 Springs: Green marked springs for the front, Red for the rear (I forgot to add this info to the manual) https://live.staticflickr.com/65535/...2e255d16_w.jpg Step C-1: You only need to install the spacer if you plan to NOT use 2-speed. If you install the spacer inside the trans, you will be in low gear, pull the shifter out and install it on the outside and you will be locked in "high" speed. https://live.staticflickr.com/65535/...f8ebc376_n.jpg Step C-2: The manual view is a little tough to make out exactly where each screw goes, i've added an image to help show their location. https://live.staticflickr.com/65535/...2bfb43fb_z.jpg Step C-5: Add a little drop of CA or other glue to help hold the M3 nut in the plastic mount. It's not usually an issue but they could pop out. Also, note to install the Right (Passenger) transmission mount first before installing the lower cover. https://live.staticflickr.com/65535/...79426ca8_z.jpg Step E-1: Typo. Two short "1" shafts should be used on the front. https://live.staticflickr.com/65535/...5c72ac6d_z.jpg Step F-2: Just showing a clearer picture for location of the shorter screws. https://live.staticflickr.com/65535/...4695b03236.jpg Step F-3: I Highly suggest tapping the holes on the tower to mount the panhard mount and the hole for the panhard bar link mount. DO NOT USE A POWER DRIVER as it you could strip these holes. Take your time getting these threaded. Our shock tower material is very stiff. https://live.staticflickr.com/65535/...6415c391fe.jpg Step F-3 (2): Depending on your servo, you may need to trim the base as pictured to clear the face of some servos. Its very minor but double check when you screw your servo down that it is flush and sitting level/perpendicular to the shock tower. https://live.staticflickr.com/65535/...110b8a2844.jpg Step F-9:Again I suggest Pre-tapping the holes with a 3mm tap. Also note, the Drivers side Left front shock uses a smaller 18mm screw to hold the shock to the tower. If you use a longer one, you will start screwing into the side of your servo case. https://live.staticflickr.com/65535/...acc20513_c.jpg Step F-10: Again, I suggest Pre-tapping the holes with a 3mm tap and NOT use a power driver. https://live.staticflickr.com/65535/...ba81d044_z.jpg Step H-2: Again I suggest Pre-tapping the top holes for the brace. Also, when installing the motor cover, hand tighten these as it is easy to over tighten and break the cover if you has a power driver. https://live.staticflickr.com/65535/...19647e85_z.jpg Step J-5: Typo here, the screws should be M3 x 12mm and not M2.5 x 12 as noted in the manual. The hardware in the parts bag is correct. https://live.staticflickr.com/65535/...17df608b_c.jpg |
Re: SCX10-III: Things to know before you build yours (Tips) Reserving this spot for additional posts and updates if needed. Rich |
Re: SCX10-III: Things to know before you build yours (Tips) This reminds me fondly of a similar post you made years ago that was equally as helpful when I was building a first batch Ascender. You might sucker me into building one of these as well... |
Re: SCX10-III: Things to know before you build yours (Tips) Thanks for this. I'm getting antsy. |
Re: SCX10-III: Things to know before you build yours (Tips) Thanks Rich, some great info here. |
Re: SCX10-III: Things to know before you build yours (Tips) Quote:
EDIT: To reiterate what soze said below, thank you for the live addendum to the manual, Rich. And thanks for doing it on this forum. "thumbsup" |
Re: SCX10-III: Things to know before you build yours (Tips) Thanks Rich! This is definitely a great thing to see with a new release. I appreciate the time/effort put into making sure we build up our trucks right! |
Re: SCX10-III: Things to know before you build yours (Tips) Having a company own-up to its 'mistakes' is one thing (don't take what I said wrong, as I meant it in a "positive" way)...but a company that not only owns-up to its mistakes, but also provided corrections as quickly as possible is even better. Looks like Horizon Hobby as fully entrenched Axial into the Horizon Hobby family, all the way down to the best customer service. Great job Horizon Hobby, great job Axial, and great job Rich...keep up the excellent work. [emoji1690] ~ More peace, love, laughter & kindness would make the world a MUCH better place [emoji1690] |
Re: SCX10-III: Things to know before you build yours (Tips) Thanks for posting up all this info. Should help the build go more smoothly. We really appreciate having you as apart of the community here! Now I just need to find a 3mm tap. |
Re: SCX10-III: Things to know before you build yours (Tips) is the tap we need 3mm x 50 or 3mm x 60 |
Rich |
Re: SCX10-III: Things to know before you build yours (Tips) Did I read that correctly, the front and rear portal covers are different? That means the aftermarket will have to sell a front and rear specific portal weight when the time comes. Not a deal breaker but it could cause potential installation problems. Also, it looks like the portal covers are attached with only four screws? |
Re: SCX10-III: Things to know before you build yours (Tips) Thanks, Rich! I just ordered mine from RPP (couldn't believe they actually had them in stock!) so this post will no doubt be most helpful and much appreciated "thumbsup" I love to see this kind of front-loaded support "thumbsup". Quote:
Re: SCX10-III: Things to know before you build yours (Tips) Here in the german "rockcrawler.de" forum we now have the first building-thread for the SCX10 III. I will get my Kit in a few hours - its still in the DHL delivery truck. So we all here appreciate the tips of Rich Trujillo and would like to thank you for your excellent support. |
Our demo model had some serious carolina squat going on so we assumed the springs were installed on the wrong ends, went to check the manual and there was no mention of which springs go on which end. It was ultimately found way in the back under the exploded views and sure enough the springs were backwards. |
Re: SCX10-III: Things to know before you build yours (Tips) Hi, did I miss the link to the manual? If yes, sorry. If no, here you go: SCX10 III Jeep JL Wrangler Kit Manual - Multilingual SCX10 III Jeep JL Wrangler Kit Parts List and Exploded View - Multilingual Walter |
