01-14-2023, 06:23 PM | #1 |
Newbie Join Date: Jan 2023 Location: Massachusetts
| SCX III JLU Spektrum/Hobbwing KV
Contemplating on an Axial SCX JLU. And want to upgrade the motor/ESC to a 2 in 1 right away. Any thoughts here: 1800/2300? Specktrum vs HW? I like trail riding. Want to walk behind the rig as well as do some rock crawling.
01-14-2023, 06:33 PM | #2 |
Rock Crawler Join Date: Apr 2015 Location: San Marcos
| Re: SCX III JLU Spektrum/Hobbwing KV
Do you like, or see yourself using the dig function? If not, I'd recommend the lower KV motor and converting the transmission to 2 speed. I still run the stock 35t brushed motor with stock (14t) pinion gear. In 2nd gear at top speed on 3S I'd have to run, not jog to keep up with it. In 1st gear at top speed it's just slower than my natural walking pace. 2nd gear would give you the room to keep the rig ahead of you, or right there next to you. Then when it's time to crawl, 1st gear comes in handy. You can keep dig and the 2 speed together, but you'd need a second servo and possibly another channel on your radio. |
01-14-2023, 07:04 PM | #3 | |
Pebble Pounder Join Date: Jul 2021 Location: Portland
| Re: SCX III JLU Spektrum/Hobbwing KV Quote:
Go for 2300 kV, and use the two-speed option. You can always gear down the pinion or spur or both down the road. | |
01-14-2023, 07:06 PM | #4 |
No real need for dig for my trail riding. How do I convert the trans to 2 speed? I thought that if I went to a 2 in 1 brushless, I would have creep to fast at the pull of the trigger on my tx. No need of converting anything.
01-14-2023, 07:10 PM | #5 |
I have read 2300kv is good for what I want. One thing I as curious about was. how reliable Spektrum/HW is over the other. And please explain the 2-speed option, what do I have to do to the rig?
01-14-2023, 07:12 PM | #6 | |
You will appreciate the two-speed function. Speed for trail hiking/running then slows it down for the crawls. It's worth the effort and a great feature of the RTR. | |
01-14-2023, 07:17 PM | #7 |
Ok let me see if I understand. If I run the rig out of the box, the trans is one speed, and I would assume a slow speed. And converting to 2 speeds obviously lets me have low for crawling and 2nd for faster speed running around the woods? I just watched a video on this. I think the one speed is fine especially if I go brushless. Brushless in 2nd would scream. I know the electronics are all Spektrum and I was just going to leave it all Spektrum by buying the Spektrum 2 in 1. Last edited by keltron89; 01-14-2023 at 07:22 PM. |
01-14-2023, 07:25 PM | #8 | |
I use Spektrum 2-in-1s all the time with success. I believe they are made by Hobbywing. I've only had Spektrum servos die on me. | |
01-14-2023, 07:30 PM | #9 |
Understand I hear issues with Spektrum to. I know the Spektrum program card is like 2 times the cost of a HW. I hear that HW/Spectrum are the same just rebranded. But there has to be some difference between the two. I am contemplating on the Spektrum 2300KV running the rig set up as is outa the box. |
01-14-2023, 07:33 PM | #10 | |
01-14-2023, 07:36 PM | #11 |
Have not made up my mind yet. Still like to hear what others have to say. But, yes, I will post pics of my conversion.
01-14-2023, 09:30 PM | #12 |
It looks like the Hobbywing system would be nice enough to give you the spread that a 2 speed transmission would also give you, maybe even more. And the 2 speed conversion is rather complex. All of the parts are already included, but you have to tear down the entire transmission, dig section and 2 speed section in order to just rebuild them with some parts re-arranged. If you go with the Hobbywing system, you'll also need a different receiver / transmitter, as the stock ESC includes the RX in it. |
01-14-2023, 09:46 PM | #13 |
Quarry Creeper Join Date: Jan 2021 Location: in the Canyon
There's really no point in activating the two speed in the 10.3 box. The ratios are close enough that I often can't tell what gear the rig is in, and have cleared plenty of obstacles in "high" gear. The problem is that the high gear isn't high enough and low isn't low enough-- it's FDR is around 45:1 in low and 31:1 in high. Compare that to a TRX-4 two speed, which has an FDR like 65:1 in low and 26:1 in high. Regardless, the HW Fusion Pro is the best option. The only reason to go for the Spektrum is if you're already in their ecosystem and have the program card, and batteries, chargers, etc. that use the Smart stuff. I do not, so it's HW all the way. |
01-15-2023, 08:35 AM | #14 |
All great info you guys are giving me. Forums are the best so much help here I have Specktrum chager. Smart batteries, radios and a Spectrum lipo tester. So, I am Spektrum involved |
SCX III JLU Spektrum/Hobbwing KV - Similar Threads | ||||
Soze's SCX10 III Jeep JLU Build | soze | Axial SCX10 III | 29 | 11-04-2021 06:20 AM |
Axial SCX10 III Jeep JLU - Trail Run - 1/24/2021 | soze | Scale Videos! | 0 | 08-19-2021 09:59 PM |
Axial SCX10 III Rubicon JLU Waterfall Trail Run 11/29/20 | B-MOW71 | Scale Videos! | 0 | 12-06-2020 07:11 AM |
Axial SCX10 III Rubicon JLU Trail Run 9/26/2020 | B-MOW71 | Scale Videos! | 0 | 10-04-2020 08:23 AM |
