07-20-2011, 12:07 PM | #1 |
Rock Stacker Join Date: Jun 2009 Location: charleston
| Wraith Shock Questions!
Does any one know how soft the springs are and what wait oil is in the shocks?
07-20-2011, 02:08 PM | #2 |
Rock Crawler Join Date: Mar 2006 Location: Up North
| Super Softs....2.07 lbs....no idea on the oil weight though |
07-20-2011, 04:09 PM | #3 |
Quarry Creeper Join Date: Sep 2006 Location: Orange, CA
Oil is 30wt. silicone oil
07-20-2011, 07:30 PM | #4 |
ok thanks guys
07-21-2011, 11:55 AM | #5 |
Rock Stacker Join Date: Jun 2011 Location: Coquitlam
What do u guys think would be a good weight, i find my truck a little srpingy out the box, also one shock has sag due to low oil from factory... no leakage tho. Think 50 is alright
07-21-2011, 12:06 PM | #6 |
| The suspension is a little stiff from the factory. Switch to a softer spring and then thicken up the oil a little. I am running 45 wt.
07-21-2011, 01:27 PM | #7 |
| Wow...I was going to go with 80wt and Losi gold springs and 3 hole pistons |
07-21-2011, 01:39 PM | #8 |
Well that might be o.k since Axial super soft = 2.07 lbs. Losi gold spring = 1.4 lbs. Losi's are almost twice as soft right? so 80w oil instead of 30-45w is also almost half!! Am i smarter than a 5th grader? |
07-23-2011, 05:07 PM | #9 |
Pebble Pounder Join Date: Sep 2008 Location: Anniston
not to thread jack but what about swapping to SCX10 shocks? other than lowering the stance, would it have any major complications?
07-23-2011, 05:49 PM | #10 |
| I have them on mine right now. The smaller diameter doesn't give much dampening. I do not suggest them if you plan on any speed running.
07-23-2011, 08:11 PM | #11 |
[HOONIGAN] Join Date: Jan 2008 Location: Littleton
I'm using the Pro-line Slash rear shocks. They look kinda scale and they're a 3 1/2" long shock.
07-23-2011, 08:31 PM | #12 |
[HOONIGAN] Join Date: Nov 2005 Location: Grand Junction
| Slash rear shocks are 4" or a little longer depending on the rod end used, Slash front shocks are 3.5" or a little longer, again depending on the rod end used. My guess is that you have the fronts though? Axial lists the Wraith shocks at 72-103mm with different rod ends, so I guess the fronts or the rears would work, fronts probably a little better?
07-24-2011, 07:44 AM | #13 |
I wanna be Dave Join Date: Dec 2008 Location: ?
07-24-2011, 07:45 AM | #14 | ||
I will go back to my cave. | ||
07-24-2011, 09:45 AM | #15 |
I wanna be Dave Join Date: Oct 2007 Location: 801
I've got the scx shocks on mine now. The ride height is spot on, but I have yet to take it out and beat on it yet. Mine isn't really setup for speed though. Just a 35t v11 on 3s. |
07-25-2011, 12:14 AM | #16 |
RCC Addict Join Date: Aug 2007 Location: Burbank
I have the rear slash shocks on, stock there shorter they had fuel hose on the inside so I pulled them out and now there a tad longer than the stock shocks. I'm going to try 30wt and see how it gos. I am also running the blue springs top and bottom. |
