Re: KoH style Wraith Wow, nice lights...all of them! Like your narrow width with those wheels and 0.225" hubs! Did the bent links eliminate the rub at full steering? How bad was the rub? Assuming it was just on the lower links... |
Re: KoH style Wraith Quote:
The hub situation is actually a real pisser... - .225" hubs with universals and stock links rub bad! - .225" hubs with universals and bent links rub even worse! - .350" hubs with bend links and universals rub bad! Apparently the only solution is .475" hubs! Just what I wanted to do is spend another $30 and have another set of hubs laying around idle:evil:. Be warned...:roll:! |
Re: KoH style Wraith That Roof light, did come out pretty cool, I like the rock lights you put in too. Wraith is looking good8) |
Re: KoH style Wraith Wow your lighting is amazing. Daddy like! |
Re: KoH style Wraith idk whats different with your wraith and mine, but I'm running the same wheels on .225 hubs and don't have issues with my links.. I still have the "bumpstops" on the back of my knuckles. So I would assume that is why I dont hit the links with my tires. I'm also running the .700 slw v2 wheels. Not the 1in slw v2's. |
Even with the 1in ones I dont see why they would rub. |
Re: KoH style Wraith Looking sweet Eric,nicely done."thumbsup" |
Re: KoH style Wraith now that's some brightness Eric |
Re: KoH style Wraith Nice truck! What volts do the 2" rock lights use? |
Sick. All you need now is some lights. --- I am here: http://maps.google.com/maps?ll=38.946813,-104.771288 |
Re: KoH style Wraith lights are sick ill be hitting you up soon for a roof light bar soon...as for the rock lights any other color available???? |
Re: KoH style Wraith Very cool starting relative same build thanks for sharing ear mark. |
Re: KoH style Wraith couldent tell if you had to remove a front link with the cms and panhard? |
Re: KoH style Wraith couldn't you adjust you end point adjustment on the radio so the tires don't hit the links? had to on mine with 600 hubs and the SV2 1inch. |
