02-26-2012, 05:54 AM | #1 |
Newbie Join Date: Jun 2008 Location: city of smile
| how to prevent tires coming out off the beadlocks
how do you guys mount the tires on beadlock wheels? in my case it came loose at a high speed turn. my setup is tekin rs pro, redline 13.t, stock gearing. currently using stock ripsaw r35 tires from kit, mounted on cr01 beadlocks wheels with tamiya aluminum beadlocks. i have vanquish star wheels on the way, will it solve my problem? or i should do extra precautions like gluing tires? but how? thanks. |
02-26-2012, 07:23 AM | #2 |
RCC Addict Join Date: Jun 2006 Location: Durham, NC, USA
| Re: how to prevent tires coming out off the beadlocks
..some guys are having tires pop off on their VP wheels: Ripsaws + SLW V4 Losing Bead |
02-26-2012, 01:47 PM | #3 |
Rock Stacker Join Date: Jan 2012 Location: Land O' Lakes
| Re: how to prevent tires coming out off the beadlocks Get a set of Motoworx Beadlocks. No lost beads. They are the opposite of Super Light Weight though. Extra beef with these. |
02-26-2012, 03:23 PM | #4 |
Thanks for the replies guys, but getting another set of wheels is not an option for now since i already bought a vp szz star. What should i do to prevent loosing thread? Is gluing tires to an aluminum wheels is acceptable? Will a super glue stick on the aluminum of the wheels? Another option is if ill change my ripsaw to proline tsl swamper, will it solve the problem? |
02-26-2012, 03:54 PM | #5 |
Superglue should help them stick enough to solve the problem, unless the clearance is completely out of spec on the wheels/rings.
02-26-2012, 04:45 PM | #6 |
Rock Stacker Join Date: Jan 2012 Location: Birmingham
Clear silicone should bond to both and be fairly easy to remove if you want to disassemble the tire and wheel without damage or heavy cleanup of the residue. I have a tube on hand but surprisingly have not lost a bead and had to use it.
02-26-2012, 06:22 PM | #7 |
| Re: how to prevent tires coming out off the beadlocks thanks! i will try this first to my ripsaw on cr01 wheels. the silicone must be put on the side of the ring or on the wheels side?
how to prevent tires coming out off the beadlocks - Similar Threads | ||||
Gear Head 1.9" Slot Mag Beadlocks coming soon. | RPP Hobby | RPP Hobby | 20 | 02-20-2012 03:24 PM |
