10-01-2017, 08:58 AM | #1 | ||
Newbie Join Date: Feb 2012 Location: England
| Clash of the titans (motors)
So i've got a wraith on the way running a brushless setup but looking to switch to brushed as will be doing wet trailing etc. Despite being hit and miss i've had good results with the traxxas titans and wondered what peoples thoughts were on it in a wraith. It will be paired with a castle sidewinder sv3. Rotation I understand some models had the diff installed backwards thus needing the reverse rotation version? From what i've read on here when setup correctly the motor should be spinning CCW as viewed looking straight at the pinion gear as explained in another thread..... Quote:
21t vs 12t I already have 2s and 3s batteries so that is not an issue but wondered how people decide between 21t and 12t. I would like to do some fast trailing with small jumps and still be able to crawl as well so which would be the best option? Gearing I've been reading different gearing threads and wondered which would be a good starting point for my usage 21t 32 pitch 13/60 3s 32 pitch 13/56 3s 23/87 14/87 12/64 3s 11/93 20/87 3s 12t 18/87 Fitting Apparently the 21t needs fettling to fit and needs the lower link mount trimming, is there a cleaner/neater way of making it fit? | ||
10-01-2017, 12:19 PM | #2 |
I run a 12t 550 in my Wraith with a HobbyWing 1080 and couldn't be happier. It does well but throttle control is key. Or I could just dial back the end points but it's nice having some wheel speed on tap. I don't remember my hearing but with 30-45min crawling sessions it hasn't overheated. Ripping up and down trails could be a different story. I had to trim just a little off the link mount. IIRC, I used a coarse wood file to do it. It's covered by the interior or I'd take a pic. |
10-04-2017, 04:49 AM | #3 |
| Re: Clash of the titans (motors)
Thanks for the info I have a 21t spare so will try that first and see how it is on 3s.
Clash of the titans (motors) - Similar Threads | ||||
Clash of The Titans RC Drift - Presented by CowRC! | Team CowRC | Non Crawler RC's | 0 | 06-27-2013 12:23 PM |
Iron Man 2 & Clash of the Titans | 2JSC | Chit Chat | 1 | 12-16-2009 10:11 PM |
*JConcepts RC Clash* | Paul Wynn | Florida | 26 | 12-06-2008 05:49 PM |
Burining out VMG/CLASH motors!?!? | pbfrk4life | Electronics | 2 | 03-02-2007 02:04 PM |
