Why not.... for sale section build Hey everyone, decided to give the wraith another go.. it just wasn't my thing with the first one. Now I'm a little more planted and have all other classes built. So time for a project.. I got lucky an picked this up off the for sale section.. http://i1147.photobucket.com/albums/...D7331-orig.jpg Never ran! VP links VP steering rods VP vvd's Aluminum chubs an knuckles Hitec 7955 Junfac shafts Motoworkz wheels Pitbull rock beasts II's Old style CI dual foams Hinged hood Battery an electronics forward http://i1147.photobucket.com/albums/...ED679-orig.jpg Getting some inspiration from dez at a "local" comp past Sunday with his wraith J, using a bushwhacker body, I wanted to find a body donor.. well I happen to have this sitting around an haven't seen one yet.. ( which came from the for sale section, last year, as well) http://i1147.photobucket.com/albums/...1CCB4-orig.jpg I decided to get my favorite tool out, dremel, an start cutting.. http://i1147.photobucket.com/albums/...31667-orig.jpg http://i1147.photobucket.com/albums/...22EB3-orig.jpg Getting closer.. http://i1147.photobucket.com/albums/...A8378-orig.jpg http://i1147.photobucket.com/albums/...8E49A-orig.jpg Well that was it for 2a.m. cutting.. the whole body is a inch or so long, so I have to figure out how I'll cut the rest to fit.. more coming.. |
Re: Why not.... for sale section build Pic of the front clip reminds me of a karnivore krawler, you may have convinced me to go a different direction for my new build |
Re: Why not.... for sale section build Looks like you're off to a great start! What did you pay for that bad boy? |
The cost of upgrades..... I'm at a stand still between what I want an what i feel my abilities.. or maybe a step back is all it will take.. any who.. This what I'm goin for.. http://i1147.photobucket.com/albums/...BDAAA-orig.jpg This is what I'm getting.. http://i1147.photobucket.com/albums/...8B09C-orig.jpg And this is the diff.. http://i1147.photobucket.com/albums/...93556-orig.jpg From what I know, the middle needs cut an back together.. I thought bout area between the doors an matching the top an bottom of the X's up.. but no screws to hold it together.. not a body guy, its not CF.... Thought bout cutting it to match at both ends an securing it where the screws are.( in front of door an behind rear door area) Etc etc etc.. I have Ideas.. no body experience to back it up.. looking for some suggestions an help.. Edit: the issue I'm having is.. I would like to keep the rear door jam at the rear brace.. the front matching up to the hood area... |
Re: Why not.... for sale section build nice! |
Re: Why not.... for sale section build I like it, Thinking outside of the box is awesome. "thumbsup" (get better lighting) |
I think I figured out my cut.. the back door is goin to be 3rd door sized.. like a ext cab Tacoma. Take a inch out of the middle of the X on the door an match what's left? |
Take out the inch, then 'shave' the rear door off. :) Chicks dig 2 door bummers. ;) |
The doors will be last thing done.. until everything else is on place.. so I started with the rear fitment. I cut the bed in half to start getting things lined up.. http://i1147.photobucket.com/albums/...37139-orig.jpg http://i1147.photobucket.com/albums/...8E111-orig.jpg I'll get everything in place an worked over before I rebuild the body to one piece.. I also got rid of the rear portion of the "roll cage" I didn't want to cut the roof, so I bent it down behind the cab. I like it... http://i1147.photobucket.com/albums/...95FB3-orig.jpg Next is a few choices for support/bracing/looks... a little help/opinions? 1. http://i1147.photobucket.com/albums/...D5275-orig.jpg 2. http://i1147.photobucket.com/albums/...48F25-orig.jpg 3. http://i1147.photobucket.com/albums/...977ED-orig.jpg I also got electronics around.. Fxr that's getting a 4s cap, cc bec, airtronics rx, HH 17t crawlmaster, an a 7955... all for now, its what I have.. ( all thanks to the members of rcc, from the for sale section). :thumbup: |
Few more changes, in prep for my ride height.. flipped the link an shock mounts f/r.. http://i1147.photobucket.com/albums/...3F00F-orig.jpg Swapped out the shocks for another set of full aluminum wraith shocks.. http://i1147.photobucket.com/albums/...9471F-orig.jpg Its now semi droop and a 3" ride height.. http://i1147.photobucket.com/albums/...2ECE0-orig.jpg Then I decide it was time to do electronics.. at 230 a.m... I just pulled it apart.. http://i1147.photobucket.com/albums/...77696-orig.jpg So now ur all caught up. Now its time to get to work |
Re: Why not.... for sale section build Curved at the backend...if you haven't already decided. http://i706.photobucket.com/albums/w...psc778f4c0.jpg |
That's a lot of stuffs to fit in a tiny box! http://i1147.photobucket.com/albums/...4C561-orig.jpg Fxr with 25v cap, for 4s use. CC bec, an the airtronics rx.. But..... all done an fits just right! http://i1147.photobucket.com/albums/...53CF1-orig.jpg Yep, that's a 4s Battery! I also ran the motor wires under the tranny.. well I found out it didn't have too.. lol. Oh well . http://i1147.photobucket.com/albums/...14CA5-orig.jpg |
She is lookin good!!! Glad to see it gettin put to got use!!:cool: |
Re: Why not.... for sale section build Looking sweet! |
Ok, initial shake down is done.. The rig performs real good, way better then the rtr one I had.. I prolly wouldn't of got rid of it if it was half this good! Any who.. tie rod an horn kept needing tightened, which isn't any big deal.. longer screws with nuts are goin on.. the rear falenfest locker kept coming loose an 3wd is no fun! So its sitting in loctite right now. The 17t HH is pretty sick! 87/16 gearing.. plenty of torque good top end on 3s.. 4s, WOW! NOT For crawling! Tho a blip of the throttle rockets over a obstacle... Trail runs, g6, an the poker/dash run this weekend is goin to be bad a$$! The rocker II'S grip, bite, crawl, an rally race extremely well. I'm excited to get panels done an run this more tomm. I'll get some pics up as well |
Not much, but worked the rear braces with what I had on hand, that fit without modding. http://i1147.photobucket.com/albums/...1B52A-orig.jpg I'm kinda glad I didn't cut the roof off.. I like it. http://i1147.photobucket.com/albums/...38841-orig.jpg A little paint I got at rauch comp last year, figure it was a good time to use it. Get rid of that ugly stock look.. till I get the Hummer panels finished up. http://i1147.photobucket.com/albums/...B60B4-orig.jpg |
Re: Why not.... for sale section build Quote:
A little nicer than the stock look. Bout ready for its beating this weekend... http://i1147.photobucket.com/albums/...D1552-orig.jpg Not digging the hole in the hood so I'm goin to slap some quick stick on cf stuff on it for the time being.. ( it doesn't feel right, lol.. stick on cf, wtf)... http://i1147.photobucket.com/albums/...1F03B-orig.jpg The rear "tailgate" is goin to be real CF. Since the rear brace made the rear wider, I'll screw the panels to the CF.. I may also pull the roof an hit it with black.. maybe the stick on cf..? http://i1147.photobucket.com/albums/...19A19-orig.jpg |
