10-20-2014, 10:15 AM | #1 |
Pebble Pounder Join Date: Feb 2014 Location: grand forks
| g6 body on wraith |
10-20-2014, 11:38 AM | #2 |
Rock Crawler Join Date: Oct 2011 Location: Canada
| Re: g6 body on wraith
If you cut out the back portion, would it allow you to drop the body and use the wraith back cargo area? it looks like it's floating back there.
10-20-2014, 11:47 AM | #3 |
| Re: g6 body on wraith No its on the frame all the way around what you see in the back is the lower section on the battery holder area
10-20-2014, 12:02 PM | #4 |
Rock Crawler Join Date: Apr 2006 Location: Hartland, MI
I'm liking it. How did you do the body mounts?
10-20-2014, 12:08 PM | #5 |
Quarry Creeper Join Date: Oct 2013 Location: Utah
Looks really good! I like that you left the cargo area on the G6.
10-20-2014, 12:09 PM | #6 |
I have yet to get them done I will probably use sheet metal off the shock towers then use the traxxas battery holder things with just body pins in the same location as the holes in the body I will post pictures when it's complete
10-20-2014, 02:52 PM | #7 |
Do you have a pic directly from the side? How level is it?
10-20-2014, 04:45 PM | #8 |
| Re: g6 body on wraith |
10-20-2014, 05:02 PM | #9 |
Rock Crawler Join Date: Mar 2006 Location: Dogpatch
I like it.
10-20-2014, 07:03 PM | #10 |
Pebble Pounder Join Date: Mar 2013 Location: Los Angeles
| Re: g6 body on wraith Somebody correct me if I'm wrong, but I think the the G6 body is the same shell as the Poison Spyder Wraith. So if you cut out the inside it should work just like the Poison Spyder body. Keeping that back portion of the body and using the G6 cage and windshield gives it a cool and different look though! Nice work!
10-20-2014, 09:51 PM | #11 | |
| Re: g6 body on wraith Quote:
I think it is the same, I cut out a G6 and put it on my Wraith. I do like how it looks this way, though. Tough decision ahead. | |
10-20-2014, 10:02 PM | #12 |
Rock Crawler Join Date: Feb 2011 Location: s. terra firma
Crockins........ the body from the wraith poison Spyder has the body she'll cut out of it. You are correct sir.
10-21-2014, 09:37 PM | #13 |
Great from the side, I really like it!
