true bead loc rim ???? :) Does anyone know if i could mount a set axial 2.2" (56mm) wheel diameter Ripsaw R35 soft compound, 5.5" (140mm) outside diameter on a set of 2.2 true bead loc rims? These tires are the ones that come in the wraith kit but i dont want use the glue style rims.8) |
Re: true bead loc rim ???? 2.2 Rips on 2.2 bead locks? Yup, should work ;-) |
Re: true bead loc rim ???? Lies! All Lies! |
Re: true bead loc rim ???? im just asking about this cuz these tires were ment to be glued so i dont know if the tire bead is differant? |
Re: true bead loc rim ???? People use the rip saws on beadlocks all the time. Should work fine. |
Re: true bead loc rim ???? Mounted my Ripsaws to Axial XR10 (VWS) beadlocks. No issues and you retain the same wheel offset as the stock Renegade wheels included in the kit. |
Re: true bead loc rim ???? Good question RS10 - all the 2.2 tires and rims are designed to work interchangeably....there are a few exceptions but they are off brands and I cant think why you would buy them anyway |
Re: true bead loc rim ???? Quote:
Re: true bead loc rim ???? oh ok thanks for the info. what bead lock rims would you recommend that are at a cheap enough price?:) |
Re: true bead loc rim ???? Axial 2.2 beadlocks |
Re: true bead loc rim ???? ok thanks. |
Re: true bead loc rim ???? I picked up a set of XR10 wheels from here. $30ish with internal weight. They're not scale lookign but they are awesome for crawling |
