Portal axles for ar60 axles Has anyone ever seen portal axles for the ar60 axles? Iam looking to put them on my wroncho if they are out there Sent from my ADR3010 using Tapatalk 2 |
Re: Portal axles for ar60 axles There is a vendor on here that makes custom axles and I wanna say I saw a vanquish center ar60 diff housing with gmade portal axle tubes on each side thus making a portal ar60 axle "thumbsup" |
Re: Portal axles for ar60 axles Quote:
I'm sure he could do 3Racing portals too. Neither portal will handle a brushless Wraith though. |
I ment portal boxes sorry for that. I just got the wroncho together and its alot of fun but I need more ground clearance under my diff and I don't want to run 2.2s on this rig. So iam just looking to get bolt on boxes. And they need to handle brushless Sent from my ADR3010 using Tapatalk 2 |
The G-Made MIGHT be able to handle brushless, but not an extreme amount. http://www.rpphobby.com/product_p/jungm51100.htm http://www.3racing-parts.com/shop/ax...-90007446.html |
Will these bolt on to the ar60s? Sent from my ADR3010 using Tapatalk 2 |
Re: Portal axles for ar60 axles Good question. I guess I need to see if my scx knuckles will work on the ar60 |
Yea if I'm thinking correctly the inner shaft has a bit more length from bearing flange to the outer end of the dog bone on the AR60 shafts. Now that I think of it if that's the case the outer bearing would need to be left out or the housing slightly modified so the bearing fits further towards the center to allow for the shafts to be shortened. I know the stubs have a longer cup portion on the xr/AR60 variant than the scx/ax but use the same bearings so that's the easy part. :mrgreen: |
It seems like it wouldn't be to hard to do and it will give me the clearance iam looking for but how much of the turning radius will I lose? Is it possible to mix the ar60 CVD with the scx10/ax CVD? Sent from my ADR3010 using Tapatalk 2 |
Re: Portal axles for ar60 axles Look at integy for portals |
Re: Portal axles for ar60 axles |
Re: Portal axles for ar60 axles 1 Attachment(s) Check out High Altitude Performance. He was engineering portals for AR60’s. I believe they are available now. |
