Thread: Steel lower links.
Old 08-28-2014, 05:28 PM   #1
Default Steel lower links.
I'm sure I'm the last to know but I didn't see these in the threads I went through.
Traxxas 5319 pushrods are a direct fit. Two rods per pack $7 each.
So $14 for all lowers.
Now to find off the shelf uppers. Maybe putting a bend in them will shorten them enough to use as uppers.
Nicolasmj is offline   Reply With Quote
Old 08-28-2014, 05:39 PM   #2
I put bends in a set to use for uppers in the rear..worked perfectly.
Yup...you are the last to know...they have been mentioned many times here lol
allanon1965 is offline   Reply With Quote
Old 08-28-2014, 08:12 PM   #3
Default Re: Steel lower links.
Just leave the aluminum uppers with the steel lowers, that should drop your COG a bit, otherwise there steel, you can cut and tap them easily.
Heckler is offline   Reply With Quote
Steel lower links. - Similar Threads
Length for wraith lower links and twin hammer links Rckhrse General Scale Talk 0 08-22-2013 03:53 PM
