Advice on class 3 rig Looking to build my wraith to a competitive class 3 rig and would like some input and advice from some people with more experience with this than myself. At the moment I have the wraith kit version with dig transmission,mamba max pro,tekin roc412 3100kv,vanquish scale hubs,knuckles, and VVDs up front, 2.2 proline super swamper tsl sx, 2.2 rc4wd hitman beadlocks,gmade transitional shocks. Thinking of giving up the dig transmission up and go with 4ws instead. I plan to make some links with all thread and tubing, thinking of leaving the wild boar shafts as my break point for fast repairs if needed, and thinking of od/ud the axles. What should be my next move? |
Re: Advice on class 3 rig Ok I have a Wraith with both DIG and 4WS. I have more problems with the DIG servo traveling too far and knocking itself out of throw. I ONLY run ProLine Power Stroke shocks. I prefer Holmes Hobbies brushless to the TEKIN. Go Vanquish titanium links and steering. |
Re: Advice on class 3 rig I've only ran my wraith maybe 1hr tops before snapped an axle and hub lol. However in that hr I noticed issues with the dig that I didn't like over throwing being one. And not engaging everytime kinda like free wheeling in the rear. I have upgraded steering links already not sure of the brand but they work nice, should be better with no flex at the knuckle. I will look into the vanquish links, I made all my links in the past and they seem to work great. I'm very impressed with the esc motor set up I don't plan to change that, I have a HH 13t pro in my scaler with the HH brxl waterproof esc and love it in that rig. |
Re: Advice on class 3 rig Is there a specific reason for the power stroke shocks? The gmade shocks seem to be pretty smooth to me? |
Re: Advice on class 3 rig Quote:
Th e MMP and ROC motor is a solid setup, stick with it. For class 3 you will want to make sure your suspension flexes smoothly, not a ton, just smoothly. So make sure your springs are the right stiffness to allow the truck to do that without too much force. OD/UD will help you climb and turn, although the turning shouldn't be an issue with 4WS. I would replace the driveshafts. Don't build in weak links, fix them. You can build the rig to the place where you really aren't going to break parts easily. |
Re: Advice on class 3 rig Thanks for the tips Harley :). Now with OD/UD that helps with torque twist also correct? Or can that be helped with weighting the wheels? Or should I not weigh the wheels down? And what driveshafts would you go with MIP? |
Yes, MIP shafts. |
