Need help spur gears different I have a wraith spawn and the spur gear has friction pads on doesnt have the 3 screws holding it in. But the manuals im reading shows it has the 3 screws |
Re: Need help spur gears different Quote:
Whats the problem you are having? |
Is the spur gear held on by the spring and washer? Meaning if you remove the nut the spring washer etc dose the spur come off if so them Axial may just need to update the manual. My dingo kit manual said a spacer went in between the main Trans gear and the diff cups but if actually did not. |
Re: Need help spur gears different The Wraith Spawn uses new dual slipper design and 32 pitch gears. http://www.axialracing.com/assets/pr...jpg?1413564993 This is the old single slipper that uses 48 pitch gears. http://www.axialracing.com/assets/pr...jpg?1321546825 |
Re: Need help spur gears different Yes i read the manual. And was going to get gear ratio for stock motor. I bought the stuff for single slipper. So the spawn has this is it only on newer wraiths? And what gear ration do i need ? Do i still get 86/14 with 36 pitch |
Re: Need help spur gears different If you want to slow it down a little. I would get RRP#8611 AND RRP#1200. |
Re: Need help spur gears different Well i read the sticky about gears and was going to do that since i had stock motors and it said the gears are too high for stock motor is that page not for this in some aspects? Wasnt tryimg to change anything just do what it recomemded |
Re: Need help spur gears different Just buy the 1/8" (3.17mm) shaft 11 tooth pinion. Axial TowerHobbies.com | Axial Pinion Gear 32P 11T Steel 3mm Motor Shaft RRP alloy steel TowerHobbies.com | Robinson Racing Pinion Gear 32P 11T RRP Absolute heat treated steel TowerHobbies.com | Robinson Racing Pinion Gear Absolute 32P 11T |
Re: Need help spur gears different Yous is geared better than the Wraith with 48 pitch gears. It comes with 80/20. Witch equals 4 to 1 ratio, your is 4.6 to 1. Most say 5 to 1 is perfect. 56/11 is 5.09 to 1. |
