10-27-2015, 03:41 AM | #1 |
Pebble Pounder Join Date: Sep 2015 Location: Australia
| Found: Cheap, High quality alloy shocks for Wraith.
Ok, so I bought myself a cheap second hand buggy today. It was a Turnigy Trackstar Desert Racing Buggy 2WD, That's not important though... What is, is the shocks it had installed. Alloy replacement shocks for the rear. Part found here: Upgrade Rear metal shock absorber - A2030 and A2031 $10-12USD gets you a pair of alloy shocks, very high quality. Change the springs and oil and these may just be the cheapest alloy replacement around. Don't take my word for it, check out the pics. The rears are 100mm DO NOT BUY THE FRONTS. You want two sets of rears, unsure of springs the offer but they may do some ultra sorts for us crawlers, I'm more interested in the bodies, as I use my own springs and oil. I'm not one to hype something that isn't worth it, if you have a low budget or even looking for a cheaper than stock plastic replacement, do not overlook these guys. The build quality in hand is top notch. YOU MUST CHANGE OIL AND SPRINGS IF USING THESE ON OUR RIGS. Enjoy ;) |
10-27-2015, 03:43 AM | #2 |
| Re: Found: Cheap, High quality alloy shocks for Wraith.
Oh forgot to mention these come standard with metal rod end balls, as pictured. These are 100mm, if I remember right wraith is 103mm. |
10-27-2015, 05:39 PM | #3 |
Look pretty nice, shafts are not ti-n coated? Spring diameter looks same as Axial? EDIT: HK might sell more if they included specs with eye to eye length LOL> Last edited by Natedog; 10-27-2015 at 05:51 PM. |
10-27-2015, 05:50 PM | #4 |
Unsure of what shafts are made of was told, they may need a light sand when they arrive but mine seem very well made and robust, would be surprised if they were coated. It appears the top of the shock is solid and changing of the Spring must be done by undoing the threaded rod ed. Spring OD is near identical, either way axial springs fit, as shown in pics below ;) |
10-28-2015, 01:53 AM | #5 | |
Quarry Creeper Join Date: Aug 2014 Location: holland
| Re: Found: Cheap, High quality alloy shocks for Wraith. Quote:
If the flange that hold the bottom side of the spring is the standard one: Pull up the spring 1/2" Push up the retainer, off the rod end. Slide the retainer sideways off the shaft via the gap in the retainer. Release the spring and it'll jump right in you lap. Mounting springs (of your choice) follow the same steps backwards (Spring won't jump over the shock by it self ;) ) looks like a solid shock BTW. HobbyKing hasn't disappointed me yet. For their prices I'm willing to accept (a little) less then bulletproof quality. But failures are dealt with very accurate and promptly. (twice, out of 100+ ordered items.) Last edited by wouterb; 10-28-2015 at 02:05 AM. | |
10-28-2015, 01:58 AM | #6 | |
Thanks mate! Didn't spend enough time looking at, I'm glad you told me, gonna save me a bunch of time cause I wouldn't of even tried another way ! Cheers for looking out dude. | |
11-02-2015, 06:45 PM | #7 |
Rock Stacker Join Date: Oct 2015 Location: NKY
Those are pretty slick and you can't beat them for $12. A little big for my MRC though I think.
11-02-2015, 07:10 PM | #8 |
Rock Crawler Join Date: Oct 2006 Location: New Tripoli, PA
Nice find, they look pretty decent.
11-07-2015, 04:30 AM | #9 |
I wanna be Dave Join Date: Mar 2013 Location: Minden
I changed out different rod ends and got stock Wraith shocks to 100mm to use on my SCX10's and the springs come off like a Wraith does also
11-08-2015, 12:20 PM | #10 |
Pebble Pounder Join Date: Jun 2006 Location: Grand Blanc/Traverse City
I just order 2 sets, i found out if you open the page they are on and wait for a while it will pop up and tell you that you can get a discount on them if you add them to your cart... looking forward to replacing the crappy leaking stockers on my wroncho |
11-08-2015, 01:42 PM | #11 |
| Re: Found: Cheap, High quality alloy shocks for Wraith. I like that about HobbyKing. |
Found: Cheap, High quality alloy shocks for Wraith. - Similar Threads | ||||
High quality Crawler video | Straffa | Videos! | 1 | 08-29-2012 08:35 PM |
high quality 3.5" shocks? | STANG KILLA SS | General Crawlers | 7 | 01-11-2008 11:22 PM |
Found Aluminum Brazing Alloy That Works | Robb | Tools, and Procedures | 3 | 06-10-2006 06:59 PM |
