Thread: 4 pole brushless with 5mm output shaft
Old 02-16-2016, 12:49 PM   #1
Default 4 pole brushless with 5mm output shaft
Anyone run anything like this here? I have one I plan on using for a bouncer setup and having trouble getting a spur gear/ pinion setup. It's a 550 3500kv
Sent from my SM-G920R4 using Tapatalk
LamChop is offline   Reply With Quote
Old 02-16-2016, 01:29 PM   #2
Default Re: 4 pole brushless with 5mm output shaft
What are you having trouble with? 5mm 32p pinions go down to like 9t.
maslin is offline   Reply With Quote
Old 02-16-2016, 01:41 PM   #3
From who?
Old 02-16-2016, 01:43 PM   #4
Robinson Racing, Novak, and Associated to name a few.
svt923 is offline   Reply With Quote
Old 02-16-2016, 02:03 PM   #5
Robinson Racing Products - Products and Pricing 5MM BORE MOTOR PINIONS
RRP has always been my go to pinion, the standard set screw is annoying though.
And I was wrong, they stop at 11t. 11/64 or so will be plenty slow, 12/60 ish is pretty good at 3500kv.
Old 02-16-2016, 02:13 PM   #6
It will be a dual purpose rig, it will see some time at a short course track as well, 12/60 will still be good enough with the gear reduction from the driveline?
Old 02-16-2016, 03:01 PM   #7
Set aside a small chunk of change if you plan on running a Wraith on the track. You will break, constantly.
I bailed on the go fast wraith, went to a bomber. I still break it every time out, but not nearly as bad as the wraith.
Short wheel base with locked solid axles and more power/speed than needed doesn't end well. Lots of fun, but doesn't end well.
Old 02-16-2016, 03:31 PM   #8
It's not technically a wraith... it's got a wraith skid and trans. IFS front suspension with unlocked dif and vaterra koh rear axle. Just posted in here due to what I'm using for driveline
Old 02-16-2016, 04:34 PM   #9
5mm motor shafts are THE way to go. The smaller 3mm shafts can break under stupid usage. Been there.
I've seen 32 pitch 5mm down to 10 tooth from someone at one point but 11 tooth Robinson is readily available.
WHITE-TRASH is offline   Reply With Quote
Old 02-17-2016, 06:59 AM   #10
Well that's better. I would go considerably faster, 14/56 or so and check for heat.
4 pole brushless with 5mm output shaft - Similar Threads
3mm motor output shaft to 5mm maxPOWAAA Newbie General 10 02-21-2015 03:42 PM
maxx shaft output to 5mm adapter/ tbilz Axial AX-10 Scorpion 5 06-04-2011 11:42 AM
