02-15-2015, 10:59 AM | #1 |
Rock Stacker Join Date: Jan 2015
| Scx10/ax10 trans on Wraith skid
Hey guys, I've been searching all morning and have found a few solutions but nothing in stock unfortunately. I build a full tube wroncho with a wraith skid. I used an scx10 trans and I've seem to hit a wall. Because the scx10 trans is shorter than the wraith trans my rear driveshaft is hitting the skid. I have already clearanced the skid as much as possible with a file but it's still hitting on full droop. I know supershafty has extended outputs but they are out of stock. Would you guys suggest just putting the axial dig components on the back of the trans so it's the same as the wraith or are there any other companies that make extended outputs for my scx10 trans? I also thought about the hot racing dig unit to get that rear output away from the trans but it doesn't have the thru pin style outputs. Last option I was hoping someone could shed some light on is upgrading to mip shafts which has the 5mm longer yokes on the trans side and hopefully that would be enough.. MIP Spline CVD™ Center Drive Kit, Axial Wraith #11116 Thanks! |
02-15-2015, 11:05 AM | #2 |
Newbie Join Date: Feb 2015 Location: duluth
| Re: Scx10/ax10 trans on Wraith skid
I may not be right but im pretty sure the mips wojld work. It wouldnt hurt to try the wraith dig stuff on the back if you have it. Sweet build btw, I really want to build a wroncho but first I gotta get experience with scx10s first haha
02-15-2015, 11:21 AM | #3 |
Holmes Hobbies makes extended outputs for the ax10 trans. I was told they make it work with the wraith skid directly from Holmes. http://holmeshobbies.com/Holmes-Torq...-Outdrive.html |
02-15-2015, 11:28 AM | #4 | ||
| Re: Scx10/ax10 trans on Wraith skid Quote:
Ordering now. Just placed an order on Thursday morning with holmes to! | ||
05-18-2016, 10:30 AM | #5 |
Pebble Pounder Join Date: Mar 2011 Location: Saxonia
to late but easy fix is to flip the rear axle and use a longer mip a center diff axle can help to |
05-18-2016, 11:55 AM | #6 |
I run 2 of those Holmes extended outputs in AX10/SCX10 housings. One I faced the longer output forward so I could clear a Traxxas Maxx shaft on the spur. The other I run to the rear to clear the Wraith skid. It's strong and versatile.
