Currie F9 axles Wanted to hear from guys running the F9's to see how yall like em. I was thinking of getting a set but my only hold up is getting hung up on rocks, but maybe the diamond design helps with that problem. Just wanted to hear what you guys thought before I spend $300. Thanx! |
Re: Currie F9 axles Yeah the lower lip on the bottom of the differential under the 3rd member likes to catch stuff, but over time it kinda rounds out. I had them on my wraith but took them off in favor of plastic housings...its a crawler so they were cool, but the plastic slides a whole lot better. They went on my go fast bomber where getting caught isnt as big of an issue. |
Re: Currie F9 axles Maybe I'll just buy one axle for the front and try that. To bad they don't offer them in grey. |
Re: Currie F9 axles Be aware some are having issues with stripped lockers in the front. Apparently, the overall housing width is ~2-3mm wider thus pulling the axle shafts farther out of the locker and causing less than enough shaft engagement in the locker which leads to them stripping out. Some axle shafts and lockers help the issue because they are designed to give more contact and some make the issue worse. VP has not chimed in yet to address the issue. Check out the F9 thread in the General Crawlers section. |
Re: Currie F9 axles You can try the SSD axles, similar style, diamond axles. They offer a nifty Delrin skid for the diff that protects the 3rd member, and they use fewer bolts. Available in grey or black, a little less money too. Sold at RPP and other shops. Centered rear available or use the front offset with their other truss for the rear if you prefer. Run by a lot of folks. |
Re: Currie F9 axles 1 Attachment(s) IMHO, SSD is a much better "Diamond" axle option. I've ran them and their quality is top shelf. The one piece housings are very nice. |
Re: Currie F9 axles I guess I'll try SSD out. The rear axle is a great deal at $110 and includes axle shafts that's awesome! I gotta decide on black or grey. |
Re: Currie F9 axles Quote:
Thanks for that SCREAMER. Unfortunately both my F9 assemblies showed up yesterday. Sure wish I would have researched it more! Hopefully I can find the correct shaft & locker? |
Re: Currie F9 axles To maximize engagement in the front you'll need to run VP VVDs because they have longer shaft tangs. I run these in 3 trucks and they are very strong and rebuildable. As for locker, I'd go with the VP Incision spool or Holmes spool. Good luck and let us know how it goes. On a side note: I'd assemble the front and rear pumpkins and tubes and then measure the width. If they are too wide, and knowing this will cause issue, I'd call VP and return them or ask them to send you the right length tubes. Hold them accountable for your hard earned money! |
SCREAMER, where've you been all my life, lol? I have NOT been getting much asked for help....not here but it looks like this is the right place. Couldn't a person tube up the pumpkin & get an overall length right away to keep from having to assemble for nothing? |
The truss also goes end to end, perfectly to the splines. They would have to redo one of the tubes and the truss, I'm guessing that won't happen. |
Re: Currie F9 axles Maslin's right. I'd just return them and go with SSDs. They're cheaper and have a Delrin skid available to keep them from acting like a boat anchor on rocks. rtmike, PM me anytime, I'm always glad to help. |
Re: Currie F9 axles I've had my issues with a set of f9's. I worked the kinks out myself, it was rather frustrating, and time consuming; but in the end I do enjoy the axles. Will say though, I highly dislike the c-clip style retainer for the outer bearings, as I've tried multiple different c-clip retaining tool removers and none seem to fit proper enough. Might be because I had to shave down the axle tubes about a mm to keep them from binding down on the hexes though :/ |
Re: Currie F9 axles Yeah, that's a lot of bs to go through for that kind of money. I love VP stuff but they have a few products that miss the mark and have me scratching my head, why. Their customer service is about the same, sometimes awesome, sometimes hard to even contact anyone after several tries. |
Re: Currie F9 axles I am honestly still on the fence about getting metal axles. I already have beef tubes and stuff like that so idk lol. On the other hand it would be nice to get rid of that rear truss back there. When I break those center drive shafts in the ssd diamond axle I'll have to order online vs going to my LHS and getting a set the same day. |
Re: Currie F9 axles It is a bit more convenient to have a LHS to run to for parts when you need them today. My issue was spending $20 every time I bent a short side axle shaft and had to go buy the set to get one axle shaft. With a centered diff you get twice as many replacements because they are all the same length. I just make it a point to order and keep spares on hand now and when I swap in a replacement, I make an order the same day. It just takes a little better planning but it's nice to have one length rear shafts. SSD does have some very nice HD replacement shafts that eliminate the through pin with a keyed titanium hex. That through pin hole is a major weak spot so it was a good move for SSD to get rid of it with the new design. |
Re: Currie F9 axles I measured my front axle again. The width with chubs installed is spot on to the plastic housing. The difference in width is with the bare housing, the bearings press in to the ends and I believe are holding the axles further out. By press in I mean press in with your body weight on a sturdy table. You have to completely remove the axle and drop out to get them out with a punch and hammer. Tight tolerances are a good thing, but it seems a bit extreme. |
